Author Topic: need some help on gearing...  (Read 2025 times)
JoeWelder
  • Turtle Points: -4
  • Male Posts: 146
  • Member since Jan '09
  • Tonka
« on: Apr 23, 2009, 05:19:38 PM »
this is the first toyota ive had and i still got the stock gears, i know i need to gear down so what kind of gears am i looking for? ring and pinion? ive seen comon numbers floating around like 5.88 and 4 something, but what gear is smaller? i know theyr kind of tricky but im tryin to understand the numbers
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: need some help on gearing...
« Reply #1 on: Apr 23, 2009, 05:31:56 PM »
Need more info, what are your plans? Bigger tires, what size, going to rockcrawl it, mallcrawl, let us know and we can move you in the right direction.  FYI in the ring & pinion dept. it's 4:88 and 5:29, right now you probably are running 4:10.
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #2 on: Apr 23, 2009, 05:41:37 PM »
probably plan on staying where im at for tires, etc. its all in my sig....i mainly play out in the mud/woods but a little bit of everything....but i need smaller gears so i can mainly get going faster on the road and just have a smaller 1st gear in general. after the gears, i plan on going dual tcase
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Apr 23, 2009, 05:45:13 PM »
4:88's would bring you back to almost stock and 5:29's would put you lower than stock on 33's. I'd go with the 4:88's since the 5:29's would kill your top end.
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #4 on: Apr 23, 2009, 05:46:18 PM »
still kill my top end even with the 5 speed in my truck?
  • Momentum Man
  • Lego Enforcement
« Reply #5 on: Apr 23, 2009, 05:47:37 PM »
Even with the 5 speed, your rpm would be up there.
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #6 on: Apr 23, 2009, 05:49:23 PM »
any specific brand to stay away from? or anythingelse i should know while looking for a set
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #7 on: Apr 25, 2009, 08:47:51 PM »
W/the 20r, you might opt for 5.29's.  A lot of people like the performance of the 5.29's w/33's and the 4cy.  It would also allow you to move up to 35's if/when you wanted to.  Check out these Calculators, you can plat around w/different gear sizes and get the mph or rpm's.  Marlin's site has Transmission Gearing Chart.  At 70mph, 4.88's and 33's= 2959 and 5.29's w/33's=3208, just at the beginning of the power band.  Right now w/4.10's and 33's you are at 2486 rpm's at 70.  Of course this is using the stated tires size of 33", and not the on vehicle height, so the rpm's could be a little higher, but still not that high.
Last post Mar 18, 2005, 07:13:23 AM
by 79coyotefrg
Last post May 20, 2005, 09:08:19 PM
by HaloFan1
Last post Apr 17, 2010, 08:15:56 AM
by 8D3TOY
Last post May 28, 2010, 09:12:10 PM
by Greiner
Last post Mar 04, 2011, 03:30:00 AM
by GreenYoterKrawler
