So, why are you converting over to AN fittings? It would make more sense to stay with factory. That way every parts store has what you need if you need something.
JIC and AN are not the same. I also believe that th AN fittings have a 45 deg flare compared to a 37deg flare on the JIC.
if you scroll down on this page to "Flared fitting type", mcmaster-carr gives you the choice of AN or JIC when searching for "37 degree fitting", also stating that the AN is simply a tighter tolerance. They also mention a fitting that is not good for higher pressure that is a 45 degree fitting, is this what you are thinking of?
Started by COToy91 Toyota Pickup/4Runner Tech 1979-95
Started by craigellis77 Toyota Pickup/4Runner Tech 1979-95
Started by zippo Engine
Started by emsvitil Engine
Started by emsvitil Toyota Pickup/4Runner Tech 1979-95
