Author Topic: Toyota break line fittings.  (Read 3621 times)
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« on: Apr 13, 2009, 05:51:53 PM »
What thread are toyota brake line fittings?  I am looking at converting to AN fittings.
Thanks
PZ
  • Turtle Points: 2872
  • Male Posts: 8,707
Re: Toyota break line fittings.
« Reply #1 on: Apr 13, 2009, 06:02:37 PM »
10mmX1, i beleive, and i think they use a odd double flare on the lines, might want to double check that
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #2 on: Apr 13, 2009, 06:04:19 PM »
10mx1.0 is correct. There is, however, nothing odd about the flare. It is a standard inverted (double) flare.
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #3 on: Apr 13, 2009, 06:18:09 PM »
THIS PART WILL NOT WORK!!!!!
thanks.  And no there is nothing different about their double flare.
I think this is what I am looking for
http://www.mcmaster.com/#4545k216/=1fmkq7
That will work in the caliper, now I need something to couple with the break line.  Mcmaster doesn't seem to have any female M10-1 fittings.
PZ
« Last Edit: Apr 14, 2009, 08:22:50 PM by Phazertwo »
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #4 on: Apr 14, 2009, 08:01:38 PM »
So, why are you converting over to AN fittings?   :headscratch:
It would make more sense to stay with factory.  That way every parts store has what you need if you need something.
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #5 on: Apr 14, 2009, 08:21:14 PM »
Well, parts stores have stock length hoses, which may or may not work on my truck when it is at ride hight, much less flexing.  That is IF they have the hose.  There is also some Nissan hose that is much longer that works for lifted rigs, but once again, thats IF they have it.
The advantage is is any race shop carries LOTS and LOTS of AN hoses. They are the same as JIC fittings (use on industrial hydraulics).  Also, the break lines go from $85 (from marlin) to ~$30, and I can get them in ANY length, from 6 inches to 12 feet. For that price I will simply carry an extra or two.  This also makes me compatible with my friends (several of us are doing this at the same time, so that we all have the same brake hoses) so a replacement on the trail should be ready at hand.
Also, I plan to change the front so that it only has one hose going down to the axle, than hard line on the axle with two smaller hose at the knuckles.  This will put everything in a much safer stop than it is right now, and it will be much cheaper to replace, and simply work on. Anyone who has worked with AN fittings knows they are much better than inverted flare fittings to work with.
PZ
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #6 on: Apr 14, 2009, 08:21:53 PM »
Also, that MCmastercarr part WILL NOT WORK!!!
MC387
  • Turtle Points: -4
« Reply #7 on: Apr 16, 2009, 08:26:29 AM »
JIC and AN are not the same.  Jic and an have different threads.  Though they will probably thread together, and may even work I wouldn't want to stake my life (brakes) on it.  I also believe that th AN fittings have a 45 deg flare compared to a 37deg flare on the JIC.
« Last Edit: Apr 16, 2009, 08:44:24 AM by MC387 »
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #8 on: Apr 16, 2009, 11:58:49 AM »
JIC and AN are not the same. I also believe that th AN fittings have a 45 deg flare compared to a 37deg flare on the JIC.
I believe you are correct
Time to go wheelin!
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #9 on: Apr 16, 2009, 10:10:50 PM »
From my research a JIC and AN fitting are the same.  A AN fitting stands for "air force and navy fitting" and they are manufactured to a higher tolerance, but other than that, they are the same.  They are both 37 degree fittings, I have a collection of both from many different projects, and once I let them float around in the same bin, I can't tell the difference.  The difference between a 45 degree fitting, and 37 degree fitting is quite a bit, and I think it would be hard for me to mistake them as the same.
http://www.mcmaster.com/#37-degree-tube-fittings/=1h931u
if you scroll down on this page to "Flared fitting type", mcmaster-carr gives you the choice of AN or JIC when searching for "37 degree fitting", also stating that the AN is simply a tighter tolerance.   They also mention a fitting that is not good for higher pressure that is a 45 degree fitting, is this what you are thinking of?
http://www.autoperformanceengineering.com/html/AN_Thread_Sizes.html
From the table on this sheet, you can see that a AN 4 has the same threads as the JIC fitting that I linked above.
This is what I have found, however if you did find something that says otherwise PLEASE post it up so that I can see it for myself, if what you say is true, than I would really like to see where you found your info, for my own safety.
PZ
mudmaster
  • Male Posts: 2,854
« Reply #10 on: Apr 17, 2009, 10:38:59 AM »
This is what I was thinking of. Looks like you have done plenty of research on this. I think you will be fine.
Time to go wheelin!
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #11 on: Apr 29, 2009, 06:44:52 PM »
So, I have done a little more searching since I found out that the Mcmastercarr fitting won't work.
Here is what I really need. This website is also a good place to get AN lines from.
The fitting that fits a Toyota is the M10x1 Japanese.
http://www.speedwaymotors.com/AN-to-IFM-Adapters,6462.html
Here is the brake hose that I plan on running.
http://www.speedwaymotors.com/KEVLAR-BRAKE-LINES,5698.html
To get a price you have to select a size.  The AN4 that I plan on running is only $13 for a 12in which I plan on running from the axle to the calipers, and than a 18in or 22in, that is $17 or less, line from the axle to the frame.
PZ
« Last Edit: Apr 29, 2009, 06:59:36 PM by Phazertwo »
Phazertwo [OP]
  • Turtle Points: 8
  • Male Posts: 812
« Reply #12 on: Apr 29, 2009, 07:18:31 PM »
After going over everything that I need, it would not be cheaper than break lines from marlin.  However still nifty.
PZ
Last post Jul 07, 2008, 09:05:49 PM
by 79coyotefrg
Last post Nov 06, 2008, 07:54:35 AM
by craigellis77
Last post Dec 29, 2009, 04:04:41 AM
by zippo
Last post Jul 07, 2010, 08:00:07 PM
by emsvitil
Last post Feb 17, 2012, 09:23:32 PM
by yotaneck13
