one last noob question. do i need to pull the axle shafts before i weld on the shock tabs or can i just do it with the axle complete. and should i use long or short tabs? and ill just go for the new springs. bags are around 200 bucks and wont really "fix" the problem.
ok the trailer in question here has a dry weight of 900 lbs. so wet and loaded its about 1250 tops.. the tongue weight is next to nothing i can move it around the yard by hand. i put about 250 tops in the bed when camping, plus the campershell and kayak. so overall its not a heavy load at all. Even with this weight you think the allpros will be to soft? thanks again for the info im just trying to pick the right setup. im also having trouble finding the pro comp and superlift leafs for the 99 taco...
im still having trouble finding a 3" leaf for the 99 tacoma in the pro comp or superlift. any links would be greatly appreciated. or a place you can direct me to where i may find them. i search for them but cant find 3" rears.
Started by lubo General 4WD Discussion
Started by weirdtimes_7 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by bobby7872 General 4WD Discussion
Started by 87toyotaman Toyota Pickup/4Runner Tech 1979-95
Started by gdunkle « 1 2 » Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
