Author Topic: Less MPG with Duals?  (Read 2729 times)
Toy1
  • Male Posts: 86
  • Member since Feb '05
« on: Mar 29, 2009, 01:41:47 PM »
Is it normal with dual t-case that I get less MPG at Highway,or do i have a issue here?
4.7 front and 2.28 rear.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Less MPG with Duals?
« Reply #1 on: Mar 29, 2009, 01:49:03 PM »
unless you are running low range on the freeway, there shouldnt be any effect.... hi range is still the same as it's always been
now if this was a comparison of before and after, you have an extra tcase now, and thats heavier than what your truck used to be......
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Mar 29, 2009, 03:08:53 PM »
You are turning more gears which means more drag.
  • Male Posts: 8,707
« Reply #3 on: Mar 29, 2009, 03:23:09 PM »
yes, but wouldnt their be even more mpg loss in the city as well? he didn't say he had a problem with that..... and its still 1:1 in hi range......
V-Man
  • Turtle Points: 29
  • Male Posts: 792
  • Member since Sep '04
« Reply #4 on: Mar 29, 2009, 03:28:55 PM »
Well no he did not, but it's hard to track MPG in stop and go traffic.. But more gears and more turning mass equals more drag..
 What else has he done to the truck...tires? diff ratio....too high, too low?  etc
 :dunno:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Mar 29, 2009, 05:06:47 PM »
1, maybe 2 mpg, if anything more  you have another problem
OOPS
  • Male Posts: 2,561
« Reply #6 on: Mar 29, 2009, 06:00:31 PM »
You still have more gears turning, does not matter they are still turning.
Some people think that adding stuff to your rigs does nothing to your MPG. Lifting, bigger, wider tires mkes it like you are pushing a brick down the road. With all the stuff I have done to mine plus being a 3.0 I get 9-10 MPG.
SocalWheeler71
  • Turtle Points: 2
  • Male Posts: 269
  • Member since Nov '07
  • Trail rig is back up and running... yay trail rig!
« Reply #7 on: Mar 29, 2009, 06:05:36 PM »
For those that are unfamiliar with the inside of a Toy tcase, the reduction gears are always spinning whether they are engaged or not. So its that much more drag, I would imagine about 1-2 MPG.
Toy1 [OP]
  • Male Posts: 86
« Reply #8 on: Apr 01, 2009, 12:29:29 PM »
Thank you for all reply`s :)
It is a 96 XCab 2.4 Turbo Diesel with sas 5.29 and 38" tires.
Around 4700 lbs
Before dual it used 0.29 gallons on 6.2 miles or 1.1 liters on 10 km
now it use 0.4 gallons on 6.2 miles or 1.5 on 10 km
I understand that there would be more drag and weight when an extra tcase are mounted.
but I think that all the stuff are the answer for my MPG,more weight less MPG :hammerhead:
Thank you anyway :thumbs:
« Last Edit: Apr 01, 2009, 12:41:50 PM by Toy1 »
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #9 on: Apr 01, 2009, 12:47:14 PM »
My guess is that it gets nearly the same mileage but you are unconsciously using a heavier foot to compensate for the increased drag and resistance.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #10 on: Apr 01, 2009, 01:07:06 PM »
If you're only going 6.2 miles, the transmission/transfer cases won't even be warmed up......
The thicker oil would be lots of drag...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Toy1 [OP]
  • Male Posts: 86
« Reply #11 on: Apr 02, 2009, 11:40:37 AM »
We measure liters used on 10 km like you say mpg :)
Checked my airfilter today and it was very dirty,so I hope it helps to clean it.
Every time I fill up I do a check of how many km driven and how much diesel used.
Gasoline and diesel are expensive in Norway around $ 7 for 1 gallon
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #12 on: Apr 02, 2009, 01:55:24 PM »
I thought it was liters per 100km........
So with the shorter distance, I thought that was all you were travelling.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post May 02, 2006, 11:27:01 AM
by 79coyotefrg
Duals or 4.7
Last post Aug 24, 2008, 06:41:19 PM
by Duffil
Last post May 01, 2009, 06:13:48 PM
by dniel
Last post Jun 18, 2009, 07:57:23 PM
by Ghtoyrunner
Last post May 11, 2010, 11:00:03 PM
by dntsdad
