Author Topic: Auto tranny  (Read 2320 times)
sigman
  • Male Posts: 86
  • Member since Dec '07
Auto tranny
« on: Mar 28, 2009, 12:27:26 AM »
 I have an 86 Runner with an auto tranny. After a run in low 4, the AT light comes on and stays on for awhile. I was wondering if it is possible to wire up a mech gauge instead of the warning light? If so do anybody know of a supplier of a tranny temp gauge? If not can I use a engine temp gauge?
Why won't the DMV recognize mud as a color?
Silly Jeepers, Jeeps are for mailmen!
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
Re: Auto tranny
« Reply #1 on: Mar 28, 2009, 12:28:50 AM »
engine temp will work fine....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: Auto tranny
« Reply #2 on: Apr 04, 2009, 09:59:39 PM »
The temp light is coming on because the transmission is overheating as a result of going slow in low range. Most often this is caused by a faulty fan clutch. You are not getting enough air flow through the radiator and the auto is overheating. Add silicon to the factory fan clutch and/or add a trans cooler in front of your radiator.
I am hoping that you do not have low oil pressure and worn transmission componets.
The engine temp gauge will not solve the problem.
Marlin
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Re: Auto tranny
« Reply #3 on: Apr 05, 2009, 03:54:39 PM »
b&m makes one
sigman [OP]
  • Male Posts: 86
Re: Auto tranny
« Reply #4 on: Apr 17, 2009, 01:57:50 AM »
Thank you everyone.  :clap2:
Last post Jan 02, 2010, 01:37:09 PM
by longzuk
Last post Jan 08, 2010, 03:09:32 PM
by Travis H
Last post Mar 02, 2012, 05:57:31 PM
by Tungsten Slayer
Last post Feb 14, 2012, 08:05:13 PM
by johnny916
Last post Apr 08, 2013, 01:20:07 AM
by Rocksurfer
