tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
89sastoyo
I just recently got my license suspended so I decided the time I'm not driving my truck ill just build it into a trailer queen  :qtip:. The plans
Flat belly
build the front axle I just bought using the birfield eliminator kit it came with and buying truss and knuckle rebuild kits,also a lockright and 5.29s taking the arps studs from my axle and using my rear third member aswell.
Rear axle is already done with a welded third 5.29s and chromolly shafts.
Also I'm planning on selling or trading my aluminum wheels for some steel ones and buying some weld on beadlocks for it.
maybe buying some 4ds might stay with the 37s though.
I want to play around with my front springs to get some more flex out of them.
Fix the body damage i got from laying it on its side in a ditch, I need to fix the A pillar to get a windshield in it.
Then paint and a cage.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
Here are a few pictures of how a bought it broken shaft in the rear had 5.29s bumper and sliders were cut off didnt come with half doors but got an extra set with good glass with it. Also it had the chromo shafts in the back seat and I had an ifs rear housing laying around I was planning on putting in my 2nd gen.
poser shot after I fixed it
Heres a couple of making my sliders and front bumper for it
92 2wd DD
first gen cab
89sastoyo
#2
duals and all that some of it wheelin then soon after found out that the third member wasnt set up by a profesional which exploded so i no longer had 4wd then just saved some pennies and bought axles from a friend.
The project now I dont have pictures of the cab damage yet but heres the axles a bought and the lovely mess I found inside them
And the good part of the axles   :yesnod:
92 2wd DD
first gen cab
coods
86bobbedtoy
89sastoyo
yeah if you look at that ring it has about a quarter inch of teeth sheered off of it and they were all in the housing. Luckily the shafts didnt get messed up or anything
92 2wd DD
first gen cab
Joey88RUNR
do you still use the toyota knuckles with the eliminator kit?
coods
89sastoyo
Quote from: Joeyotaman on March 16, 2009, 06:04:01 PM
Yeah it still has the stock knuckles everything is stock other than the spindle which comes with the kit. I was told you have to clearance some housings for the shafts to fit but it doesnt apear that this housing was grinded out or anything
92 2wd DD
first gen cab
89sastoyo
I got a little bit of work done tonight on the housing just cleaned it up and wire wheeled on it for a little while. My plans are to get it cleaned up and once the armor is on im going to powder coat it.
92 2wd DD
first gen cab
GrenadedToy
89sastoyo
Quote from: GrenadedToy on March 17, 2009, 02:57:00 AM
just spray paint it.
but I can powdercoat it for free so I figured I would then it wouldnt chip as easy :D
92 2wd DD
first gen cab
GrenadedToy
#12
i dunno about having where the trunion races go being powdercoated..
i heard metal to metal contact was bad(on skys website for why they dont powdercoat steering arms)..but dont quote me..
maybe see if anyone else has done it??
coods
you can tape off or plug anything you dont want powder coated so just the outer housing gets painted
GrenadedToy
Quote from: coods on March 17, 2009, 01:55:53 PM
Oh yeah... :hammer:
89sastoyo
yeah ill probably just tape the whole ball off on the end of the housing then just leave bolts in the drain and fill plugs just powder coat over then take them out and put new ones in  :shake:
92 2wd DD
first gen cab
coods
you gonna do it yourself?  ganna need a decent sized oven to fit your axle in
89sastoyo
yeah i have access to one thats like 4x4x6ft tall and a gun and a bunch of powdercoat.
92 2wd DD
first gen cab
coods
nice they got a big enough rack to hang it.  you just have to make sure you get it realy clean. you should prob sand blast it then right before you paint it treat it with a acetone to get any left over grease and oil off
89sastoyo
yup got it covered lol it should be pretty sweet and the knuckels to im ordereing a lockright and truss kit next week so i should get them by next friday.
92 2wd DD
first gen cab
coods
sweet ass. gonna go wheelin this weekend if you want to come
89sastoyo
maybe on saturday if i can ill let you know fridya if i can but if your going up to browns i cant caus ei work sunday
92 2wd DD
first gen cab
coods
na were just gonna hit goat. im goin to goat tomo to
boggerunner
how are the birf elims holding up, my buddy put those in his runner on 35's and they popped first trip out and took out the lockout hub too.
89sastoyo
I haven't actually used them but my friend who managed to break to stock birfs open in the same spot had them with 38s and they seemed to hold up so we'll see was his front welded or a locker?
92 2wd DD
first gen cab
GrenadedToy
Quote from: boggerunner on March 18, 2009, 10:19:12 PM
they arent the sky/randys ring and pinion kit that everyone has problems with. they are yukons.
I definately wouldnt weld your front diff adam.
89sastoyo
Quote from: GrenadedToy on March 19, 2009, 01:03:06 PM
I'm not welding it i was just wondering if that had something to do with why they broke on his friends truck im ordering a lockright next week.
92 2wd DD
first gen cab
boggerunner
i rock a welded front diff, but i have 30 spline longs with hub gears
89sastoyo
Quote from: boggerunner on March 19, 2009, 08:15:50 PM
Yeah I have a welded diff i the front right now with stock birfs rallied it with 37s didnt break a birf im sure they are about to but never broke  :greengrin:.
The thing is i borrowed a welded diff to throw in, then I found out it wasnt set up right and it ended up blowing up same person set up the one that came from the front axle I just bought. I figured it was a deal though to get a good diff that was mine to begin with welded 5.29s in the rear axle front axle with the yukon eliminator kit with vented rotors and all that cool stuff 5.29s blown but the housing is still legit for 800 bucks. My housing is bent to, its almost imposible to get a birf in and out of it.
92 2wd DD
first gen cab
89sastoyo
heres a picture of the damage from the ditch before i beat on the fender and put my other door on
And after i straightend the fender and with the new door
This week im gonna run to u pull it and cut an a pillar of another truck and cut mine out so i dont have to worry about trying to get that one straight. I am going to get an extra cab window to so it should be all fixed up by this weekend
92 2wd DD
first gen cab
