Author Topic: under frame shackle mounts  (Read 4952 times)
motoracer
  • Turtle Points: 12
  • Male Posts: 319
  • Member since Sep '07
  • my geen bean
« on: Feb 04, 2009, 12:10:52 PM »
Whats better going tru the frame to mount shackles or going under the frame. anybody running this setup, any down side to it .
pie
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: under frame shackle mounts
« Reply #1 on: Feb 06, 2009, 02:14:56 PM »
I take it this is on an 86+ during an SAS?  Through the frame, caster will be much better than having shackles mounted under the frame.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
« Reply #2 on: Feb 07, 2009, 07:10:21 AM »
yes on the sas swap. i seen were so people have mounted the shackle under the frame ,not tru it . just wanted to know the pros and cons of this set up.
pie
tryn2Crawl
  • Turtle Points: 11
  • Member since Feb '05
« Reply #3 on: Feb 07, 2009, 07:57:47 PM »
I've seen ALOT of SAS rigs with shackle into frame interference be cause of the frame not being straight shot...A bumpstop for the springs will help stop this from happening...But I know that if it has to(without a bumpstop), it wouldn't ever interfere.So, Under frame is best in my eye.Plus if your it gives you a higher lift,  if thats what you also need too....
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #4 on: Feb 07, 2009, 07:59:21 PM »
either is fine
kcdee00
  • Member since Mar '06
« Reply #5 on: Feb 07, 2009, 08:23:19 PM »
Mine are under...Thats cuz somebody i know built it that way, he didnt buy a kit.....my caster is fine b/c he also dropped the front hanger to compensate....He put stock springs up front when he built it so thats all the lift it had.  I have since put rears  up front and moved my axle ahead.  If I ever put any other springs on it, it will be too high, but right now its perfect (IMO). I havent had any problems with it....I say do it either way....
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #6 on: Feb 07, 2009, 09:46:42 PM »
mine are under the frame, and i ahvent had any problems.
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
« Reply #7 on: Feb 08, 2009, 01:50:47 PM »
thanks guys, i got 3 in lift springs,id have to go with a higher lift spring in the back, if i went under the frame. could  i get some pics of the shackles and the bracket were you mounted it to frame . thanks
pie
kcdee00
« Reply #8 on: Feb 08, 2009, 01:58:21 PM »
I can get u a pic, but mine are just stock shackles and homemade shackle hanger brackets....
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #9 on: Feb 08, 2009, 02:07:25 PM »
i was going to run mine through the frame and i did but i put my rears upfront and now my springs are bottomed out on the frame.... so now i am going to run hangers under!!! either way is fine.... as far as caster goes i am running a boomerang shackle to correct my negative caster angle!!
cederrowe
  • Member since Sep '08
« Reply #10 on: Feb 08, 2009, 02:43:06 PM »
I would run the tubes through the frame for #1 caster angle #2 the tube is alot stronger than a hanger #3 Keeping the center of gravity low in the truck
This is the way I did my 91 SAS and do not regret the extra work. The truck runs great down the road and the lower center of gravity crawling is a huge plus.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #11 on: Feb 08, 2009, 02:47:28 PM »
my toy wont sit ANY higher with the hanger under... just to let you know
i will have both (already have tube through) so if i feel like running marlins fronts i can through my 5.5'' shackles back on with Marlins springs!!
cederrowe
« Reply #12 on: Feb 08, 2009, 04:56:20 PM »
"my toy wont sit ANY higher with the hanger under... just to let you know"
 :headscratch:
The mounting point will be a solid 4 to 6 inches lower therefore increasing height of the truck.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #13 on: Feb 08, 2009, 05:08:05 PM »
different shackles...
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #14 on: Feb 08, 2009, 05:37:29 PM »
I have both options, this is under.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« Reply #15 on: Feb 08, 2009, 05:48:52 PM »
i am in the process of removing my under frame shackles and going to a stock through frame setup.
the reason being is i had my wife sit in the truck and cycle the steering for an un related problem and i noticed that the shackles swing side to side about an inch, therfore explaining why my bushings wear so fast. through the frame will reduce this a little, espesially when using braced shackles
cederrowe
« Reply #16 on: Feb 08, 2009, 06:00:07 PM »
[/quote]
Thats is reason number two, it will or can eventually rip the frame with the lower mount. And there was a reason toyota originally did this.
  • Male Posts: 8,707
« Reply #17 on: Feb 08, 2009, 06:02:30 PM »
we should all just leave our trucks stock and not have to worry about it ;)
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #18 on: Feb 08, 2009, 07:14:58 PM »
that would be boring, and i abuse the crap out of my under the frame mounts and havent had a problem.
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #19 on: Feb 08, 2009, 10:36:26 PM »
 :headscratch:
its only 3 inches and i am running boomerangs! so there you go!!!!!
Last post Dec 01, 2004, 05:51:06 AM
by WHITE_TRASH
Last post Feb 14, 2008, 01:05:27 PM
by Doable
Last post Sep 22, 2008, 07:09:57 PM
by sam2145871
Last post Jan 01, 2010, 10:23:59 AM
by WHITE_TRASH
Last post Jul 28, 2013, 10:45:57 AM
by CrazyYota
