One link what
Started by 854RUN, February 04, 2009, 07:37:08 AM
854RUN
ok so now for the dove tail and what i did with the fuel tank after the 1link
-JOSH-
COToy91
Quote from: 854RUN on February 18, 2009, 05:54:33 PM
and than the first run on the new suspension. The top spring retainer was just a piece of 2" wide by 3" long by 1/4 thick flat stock, ya it was not working that happened 2 times. It is now a 3" circle cut from 1/4" stock and COtoy91 truck that rolled into a fallen tree lol
and the springs i had on the were 2" lift front tj spring. i have since lowered it 2" with stock tj springs and took out some front leafs.
yeah i kinda fixed that issue, detent ball and spring are a little worn, tcase pops out into neutral
854RUN
that sucks, so you just have to hold the shifter so it stays in 4x4?
-JOSH-
COToy91
looking to get some 4.7 gears and ill get the stronger spring at the same time and see if that solves the issue, otherwise ill do what some people do and use a bungee cord lol
854RUN
In high school i new a guy that used a bungee on his brake peddle (peddle to seat), i don't know why i never asked i just assumed it was a jeep thing lol.
-JOSH-
TacoStewie
ever worry that the coil wont end up back in the right spot??  how does it do on the road at speeds??
4THEWKN
854RUN
LOL its not suppose to do that i needed to make bigger upper spring retainer witch i did. the coils can drop about 2" before the hit the spring retainer.  the 2x that happened i had to have COtoy91move the spring to where it needed to go as i slowly rolled froward. on the highway it fells like it did when i had leaf spring, corners are not a problem at all. the anti squat is right around 25ish so it has very good road manners.
-JOSH-
COToy91
What was the 128 bolts, nuts, and washers run you at fastenal?
Did you go with grade 5?
twistedtoy92
that one link seems pretty damn simple...... nice flex BTW!!!
Doof
Quote from: COToy91 on March 24, 2009, 05:03:54 PM
bead locks
854RUN
i bought 150 of all grade 5 for 40 to 50ish, i always go there cheep and i have a account there so i get a discount. i was going to get grade 8 but when you have 32 and only tq to 20ft-lbs g/8 is over kill and a wast of money. you buying some locks?
-JOSH-
854RUN
Quote from: twistedtoy92 on March 24, 2009, 05:32:41 PM
very simple, strong and cheap. and if done right it will preform great.
-JOSH-
COToy91
Quote from: 854RUN on March 25, 2009, 05:06:37 PM
Soon Maybe, I just bought all my hydro assist stuff, since i have no clue what i am doing maybe you can help me out a bit
854RUN
you bet and i have the tap if you dont
-JOSH-
jrock
That is cool. Weird but cool.
854RUN
Quote from: jkief86 on March 25, 2009, 06:02:47 PM
lol its not for everyone but it cool
-JOSH-
854RUN
the 150 bolts, nuts, washer were $74.50 out the door.
-JOSH-
Bs85
what did you do about the supply line for thefuel tank did you just use rubber efi hose?
854RUN
#48
Quote from: Bs85 on March 25, 2009, 06:12:31 PM
yes and barbed compression fitting on the hard line to the engine.
-JOSH-
Bs85
sweet thanks the pictures helped alot
854RUN
you bet, i had to order the compression fitting, it not just a home depot special there fitting are to big or to small i needed one in the middle if that makes sense.
-JOSH-
jrock
Yay for the Standard System.
Bs85
do you happen to remember where you ordered them or part numbers by any chance they should just be 5/16 compression fitting to 5/16 barbed end im assuming...  i tried google to find one but no luck yet thanks for the help not trying to steal your thread im just doin the exact same thing right now and all i need is those fittings
854RUN
alright ace hole lol jk that what its for ask all you wont. yes it is 5/16 compression fitting from fastenal # 69710
http://www.fastenal.com/web/products/detail.ex?sku=69710
-JOSH-
Bs85
thanks man my local hardware store ended up having the fittings so i just got to put it all together now thanks again.
854RUN
you bet good luck with it. did you move you tank?
-JOSH-
Bs85
ya to right behind the cab in the bed, i flatbellied the truck so there was no sense in leaving the tank hanging down there.
854RUN
make sense,why go throw all that just to have your fuel tank hanging down.
-JOSH-
