Author Topic: Tech of the Day - Front Axle Rebuild Tools  (Read 3640 times)
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« on: Jan 30, 2009, 07:34:09 AM »
This is for the newbies, or anyone that wants to learn
What is the minimum amount of tools you can use to rebuild a front axle (not including the 3rd member)
Off the top of my head:
10mm Socket (or 13/32")
12mm Socket (or 15/32")
14mm Socket (or 9/16")
17mm Socket (or 11/16")
19mm Socket (or 3/4")
24mm Socket (or 15/16")
54mm Socket (2-1/8" equal)
Torque Wrench from 10-90ftlbs
2 Tubes White Lithium Grease
Lock Ring Plyers (or snap ring if you like frustration)
Seal Puller (or screwdriver)
Seal Driver (or socket of equal OD)
Flat head screwdriver (for flatening 54mm nut lock tabs)
Degreaser (brake cleaner, carb cleaner)
Rags
Jack Stand
Floor Jack
3/8" Chain with hooks (to hold up the axle if you are using a Hi-Lift Jack)
Lug Wrench (or 13/16" 6 point deep socket with 12" extension)
Factory Service Manual (free download on this site)
Don't know off hand what size the socket is for the fill and drain plugs, so if somebody could come up with that, it would be great.
Anything else to add?
« Last Edit: Jan 30, 2009, 08:24:06 AM by MiniSimp »
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • USMC NO BETTER FRIEND NO WORSE ENEMY
Re: Tech of the Day - Front Axle Rebuild Tools
« Reply #1 on: Jan 30, 2009, 07:42:06 AM »
Id like to add that you need a life or a hoby other than this  :disturbed: :yupyup: you freekin offroad nerd
 :usa: :beerwhack:
except BACON
5runner
  • Male Posts: 21
  • Member since Apr '08
« Reply #2 on: Jan 30, 2009, 07:59:01 AM »
The drain plug is a 24mm or a 15/16.and the check plug is also a 24mm or 17mm. :thumbs:
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #3 on: Jan 30, 2009, 08:25:05 AM »
Kettle ->  :slap: <- Pot
Revivalist
  • Turtle Points: 3
  • Male Posts: 140
  • Member since Aug '06
  • Wheelin' with Him!
« Reply #4 on: Jan 30, 2009, 09:50:40 AM »
What about that pre-load guage to make sure the knuckles have the right pre-load. . . . I know you said the minimum amount of tools, but I wouldn't want to have to add/remove shims later because of wobble. . .
Check out our new organization, Outdoor Enthusiasts! It's a new and exciting way to raise money for trail supporting organizations! The best part is that you support trails without spending any new money!
95toyrunner
  • Turtle Points: -124
  • Male Posts: 705
  • Whaaaaaaaaaaa?!
« Reply #5 on: Jan 30, 2009, 10:48:22 AM »
how about some info on how to separate the brake rotor from the hub
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
*** YELLER ***
  • Male Posts: 4,686
« Reply #6 on: Jan 30, 2009, 10:52:12 AM »
BFH
 :hammerhead:
 :usa: :beerwhack:
except BACON
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #7 on: Jan 30, 2009, 10:55:52 AM »
Set the Assembly on an old wheel (or some other block) and take out the 2 bolts connecting them, then pound out the studs, after that it should be fairly easy to separate.
From the FSM:
« Last Edit: Jan 30, 2009, 11:04:43 AM by MiniSimp »
95toyrunner
  • Male Posts: 705
  • Whaaaaaaaaaaa?!
« Reply #8 on: Jan 30, 2009, 11:54:20 AM »
wouldn't that damage the bolt threads?
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #9 on: Jan 30, 2009, 11:56:35 AM »
You should replace them anyway, but no, put your lugnuts on flush with the top of the stud first, use a piece of wood between your lug and hammer.
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
« Reply #10 on: Jan 30, 2009, 12:08:31 PM »
WTF do you need 2 tubes of lithium grease for?  Packing the knuckles full of grease is retarded.  Just fill the birf and smear some on the outside unless you really like dealing that a mess WHEN not if the inner seal fails....
Oh and a knuckle rebuild kit would come in handy when rebuilding teh axle too... :greengrin:
Revivalist
  • Turtle Points: 3
  • Male Posts: 140
« Reply #11 on: Jan 30, 2009, 01:24:55 PM »
I was gonna mention that but I figured we're only talking tools, no parts . . .
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #12 on: Jan 30, 2009, 01:42:48 PM »
Yep.
*** YELLER ***
  • Male Posts: 4,686
« Reply #13 on: Jan 31, 2009, 07:20:51 AM »
Yep.
so how about a parts list  :dunno: :biggthumpup:
 :usa: :beerwhack:
except BACON
Last post Mar 10, 2005, 07:51:10 PM
by MiniSimp
Last post May 30, 2005, 02:17:20 PM
by 86yota
Last post Jul 09, 2006, 08:26:42 AM
by crawlerdan
Last post Jun 11, 2007, 10:53:12 PM
by 808-Yota
Last post Jun 10, 2009, 12:52:39 PM
by awhotrods
