d60 info
Started by Steve_925, January 11, 2009, 11:31:53 PM
Steve_925
so if there has been many topics on this let me know, i couldnt find any.
i just warped my toyota front housing and im pretty much building a buggy.
if i have to buy a new housing im just gonna get a dana 60.
my question is, how beefed up does a d60 need to be for a not to heavy toyota on 40's?
would i have to get chromo or maybe just some better u joints and a spare?
let me know
UA 342
STEAMFITTERS
bigarms23
a d60 and ctm ujoints and chromoly shafts should do it
Steve_925
chromoly inners too? or just the stubs. will 15" rims fit on a 60
UA 342
STEAMFITTERS
KYOTA
#3
have to grind the calipers a bit to fit inside 15's
not needed to run just 40's but a basic built 60
35 spline outers -cromo everything- ctm's long's or long's cv's- drive slugs
Steve_925
sorry im not understanding that. are you saying i need 35spline outers and full chromo and ctm's to run 40's. or i dont need all that stuff. i assume by drive slugs you mean drive flanges? idk
UA 342
STEAMFITTERS
KYOTA
kiyul4130
if you keep the 4.10s in it your going to be fine and probably wont break the shafts for awhile. it will put stress on your transfer case though and can cause output failure. if anything just get some 35 spline outer stubs and hubs, some high steer if thats what you know you want to run and gear the axle and you should be fine.
-kiyul-
ECV 7-11
KYOTA FOREVER
Steve_925
how strong are the arms that are cast into the knuckles. whats a good brand for steering arms. sky?
UA 342
STEAMFITTERS
kiyul4130
you mean how strong are the knuckles right? where the tie rod bolts in, there strong. i have WFO's high steer kit. its really strong and the arms are really beef, yet super simple design. basically most all of the aftermarket stuff for a 60 is pretty beef. id stay away from random aftermarket stuff off ebay though.
-kiyul-
ECV 7-11
KYOTA FOREVER
Steve_925
thanx for all the info. how about in the rear? im assuming since stock toyota shafts are strong enough for 37s, stock 14 bolt FF shafts should be good enough for 40s
UA 342
STEAMFITTERS
kiyul4130
a rear 60 would be fine. dish whatever you want at the 14bolt.
-kiyul-
ECV 7-11
KYOTA FOREVER
Sluice Box Hero
kyle nailed it.  keep the 4.10s and upgrade your cases.  Dual ultimates with chromo output and youll be set.  ive been running the stock 30spl outters on mine all year with no axle carnage, where last year i was breaking D44 Chromo axles every trip.
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
Steve_925
sonds good. sluice, what locker you have in the front?
UA 342
STEAMFITTERS
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
Steve_925
thats kinda what im thinkin. or spools, lockers are too damn expensive
UA 342
STEAMFITTERS
kiyul4130
dont worry, im welded/welded to.
-kiyul-
ECV 7-11
KYOTA FOREVER
Steve_925
it just pisses me off, i should have decided on them when i started. now i have to sell my axle
UA 342
STEAMFITTERS
