TURBO'S to do list (MonyRunner)
Started by TURBO, January 03, 2009, 08:58:01 PM
93tonkatoy
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/86troubles.pdf
That should be the general test procedures for all of the sensors on the 3.0. It could actually be as simple as a shorted wire somewhere. If you test all of the applicable sensors (that factor into the mixture), and they're good, I would suspect the short, or a broken wire. I think I remembered you already swapped a different ECU to test?
SAVE TELLICO post 491
TURBO
WOW  :shocking:
the Cargo ship, USS information, from japan just docked itself outside my front door.... :woohoo:
this may take awhile to unload and process.... :bananapc: :flamer:
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
Duffil
Quote from: TURBO on January 17, 2009, 12:40:08 PM
WOW  :shocking:
is that code for Marlin came to have a look?
93tonkatoy
I think that's code for - he's got a date with a ohmmeter!
TURBO
yeah i'm defintely hook'n up with an ohm meater tomarow.  but i was refering to the boat load of info 93tonkatoy posted up for me. :booya:
thanks alot man, that  :pokinit: is some valuable info... maby it will help.
I AM :screwy:!!!
TURBO
how bout this?
could this be the culprit???
I AM :screwy:!!!
TURBO
GREEN is BETTER mike... all caboose had that night was that water i'm holding
I AM :screwy:!!!
Quote from: TURBO on January 25, 2009, 10:25:45 AM
how bout this?
Is that the clutch start cancel relay? If so, then that is not your culprit since your engine at least cranks. I see a black with white stripe wire which is typically the starter signal wire.
Quote from: TURBO on January 25, 2009, 10:32:11 AM
Yeah, yeah right, we all know BLUE is BEST
TURBO
ok, well maby my spare tire is mounted in the wrong positon, and that's why it's acting like a retard
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
TURBO
well, i got a bunch of raw data back from 93tonkatoy's "boat load of info" post, and i have a bunch of stuf i need to post up about that, but for right now i want to post up a teaser pic of my cardbord bumper.
I AM :screwy:!!!
TURBO
I AM :screwy:!!!
unclejpl4x4
:psss: when it :rain: your bumper will melt you should make it out of metal.
:gap:  I like it bro can you make me one :)
White Goat
Looks great Turbo :clap2:  Now build it. Forget the runner just drive the bumper.
TURBO
so should i just junk this thing???? all it  is to me is a sad story dripping oil in the driveway.....
I AM :screwy:!!!
unclejpl4x4
Quote from: TURBO on February 26, 2009, 06:18:17 PM
what happened
TURBO
just tired of it nobody can fix it...
I AM :screwy:!!!
Let's swap in a 3.4.
Anyone wanna donate a 3.4 to TURBO?
93tonkatoy
 :think: I have a driveway it can drip oil on! :rofl2:
TheCookieMonster
Quote from: BigMike on February 26, 2009, 06:34:00 PM
i agree with mike...get rid of the 3.slow and find a 3.4 to swap in there.. im sure that will fix your problems  :thumbs:
unclejpl4x4
i have a stone drive way it can drip oil over here :)
TURBO
it's ALIVE!!!!! it runs! it finaly runs!!!!!  :woohoo:
I AM :screwy:!!!
GJToyotabug
well just dont crash it i dont think that fancy bumper will hold up
unclejpl4x4
Caboose
Turbo post up some pics of that sweet bumper!  And show everyone why i now owe you Denny's... Duct Tape is stronger that I previously thought...
"Who let the jeeps come?
Easy... easy..." -2 people on the CB
81 Toy Pickup SR5
http://board.marlincrawler.com/index.php?topic=35701.0
Daily Driver: 96 Dodge Ram 2nd DD/Tow Rig
TURBO
believe it or not, more pics coming soon!
I AM :screwy:!!!
playtoy
Hey man I also have the 3.0 and it broke the lower timing belt gear around the key way and it would jump the timing up  and down and my exhaust would glow just like that. I could be driving and turn the key off and on real fast and it would jerk the timing gear back to where it needed to be and it would run fine until it would slip back. It acted like an electrical problem to me and it took me a month to figure it out. Hope this helps I feel your pain. :beer: oops I didn't see your it runs post.
