TURBO'S to do list (MonyRunner)
Started by TURBO, January 03, 2009, 08:58:01 PM
TURBO
#120
first off, thank you everyone for your help...
second, my appologies for not posting up sooner, i kinna get a little ADD when my truck starts running all of a sudden...
turns out it was the COMPUTER GROUND!!!
ok, inside the computer are the pins that go threw the side of the computer housing, and you kno, that's where you plug your engine wireing harness in at. ok so then there is the plastic plug, and the wires come out of that and go into your wireing harness....
so yeah that is were the problem was.... wherever that brown ground wire went to, it was no longer a good'nuff ground for the engine.
so to fix it, i just spliced another wire into that brown one and ran it directly to the batery...
and just like someone fliped a switch.... the truck works perfectly now, and i've been drive'n the heck out of it....
http://s105.photobucket.com/flash/player.swf?file=http://vid105.photobucket.com/albums/m205/turbotoyotatruck/P4010185.flv
http://s105.photobucket.com/albums/m205/turbotoyotatruck/?action=view&current=P4010185.flv
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
Joey88RUNR
Found this in the Round-Up picture thread :eyebrow:
TURBO
wow! look at that rear tire tuck up in there...wow, i still surprise myself at how well i got that to fit in there...
I AM :screwy:!!!
TURBO
okay it's time to fix my power window issues.... and see'n how i dont have a camera anymore, there will be no pics, sry....
so... as of right now, none of my windows work, so i plan on getting the switches and testing them to see if they are bad...
I AM :screwy:!!!
TURBO
well, i took the switches apart and, around some of the contacts, there was some black residue... and there are these little bent peaces of metal that rock back and forth....time for some nifty bending....
I AM :screwy:!!!
Have you checked for voltage at the switches?
TURBO
naw, i was just wing'n it at the moment...
....crap! looks my multi-meter has gone MIA at the moment
I AM :screwy:!!!
TURBO
in doing this i found out i need to replace the courtesy switch on the driver's side, soooooo.... here it goes onto the list!
I AM :screwy:!!!
Have you fixed the problem with your 3VZ-TE not boosting properly yet?
TURBO
nope, not yet, i cant even find the turbo on it yet...but i'm sure it's burred in that engine compartment somewhere under that 3.slow. probly gotta unbolt the intake, pull the crank, drain the blinker fluid, use some elbow grease on the starter reservoir, and spin in circles to get to it.... i'll just wait on that for the time being.
I AM :screwy:!!!
TURBO
ok... this is what i found out so far....
if wht/blk and blu/blu are jumpered, and blu/yel is b+    =  driver's window goes down
if wht/blk and blu/yel are jumpered, and blu/blu is b+    =  driver's window goes up
if wht/blk and blu/blk are jumpered, and blu/wht is b+   =  passenger window goes down
if wht/blk and blu/wht are jumpered, and blu/blk is b+   =  passenger window goes up
i guess this means i need new switches, or the switches are not getting b+
below is a pic of the plug that goes to the master switch on the driver's side
I AM :screwy:!!!
TURBO
FIXED'ER!!!!!
well, i guess i need to find the rats that are eating my wiring harness 'cause the B+ wire is no longer B+..... figures....
I AM :screwy:!!!
TURBO
ok good night.... maybe tomorrow i can get the rear window working... any ways, night all!!!!
I AM :screwy:!!!
Quote from: TURBO on March 26, 2010, 12:36:41 AM
I think I know what happened to your wires...
What happened is that when you drank that Blue Monster, it gave you gratuitous amounts of energy, with electrolyes, turbolytes, powerlytes, more lights than your body had room for. Then you began working on your 4Runner and you were like "I'm going to do some wiring haha hehe haha hehe" and you started working on wiring so fast, mother nature was telling you to "Sloooooowwww dooowwwwnn" and you were like "screw you I'm gonna get this thing running!!" You had so much energy from that Blue Monster that you worked abnormally fast and actually disconnected that wire.
So I hope what you learned TURBO is that a Blue Monster is WAY TO POWERFUL for you to handle!!
Here is TURBO learning what REAL POWER is like
TURBO
this issue has already been solved in the monster poll....
http://board.marlincrawler.com/index.php?topic=54537.0
Quote from: TURBO on June 08, 2009, 05:36:41 PM
yeah.... where are all the unbeleavable clips of blue monster toyotas doing crazy things??? answer: there are none!  cause GREEN is the best. blue cant even get out the garadge
I AM :screwy:!!!
TURBO
ok, i'm off to pismo... be back in a week!!!
I AM :screwy:!!!
TURBO
wellp... it's been a long time sence pismo, but my catalytic converter got stolen :maddest:.... who'd a thunk???  anyways, i gotta get it ready for smog.... it failed because the hardlines got pluged up that go under the intake on 3 ohs... so now i gotta pull the upper intake off and replace the hardlines with some other ones off my old motor that should be good still (i'll check'em first)
I AM :screwy:!!!
Why don't you get some sort of security out there
TURBO
just about to finnish up on my truck for tonight... just gotta tighten down a few bolts and throw a coulple beads down
I AM :screwy:!!!
Did you get a replacement cat yet?
TURBO
yup! going up to blue canyon this weekend!!! :driving: for the Mountain Topper's Poker Run!!! :thumbs: party awn!!!  :beerchug:
I AM :screwy:!!!
TURBO
got back from the mountain toppers run... i had fun but i got a nasty scratch/dent in the tub of my 4runner, right above the right rear tire... it sux... but i learned my lesson....
I AM :screwy:!!!
TURBO
Quote from: BigMike on May 14, 2010, 11:44:03 AM
What about your
i solved that issue...
B-LANE 525 helped me out with that one... got me a cat, and i instaled it before i left... this time i not only bolted it in but i welded the flanges together so those theving bastards wont be able to steel it so easily....
I AM :screwy:!!!
TURBO
#146
here's the link for when i took my 4Runner to the 35th annual Mountain Toppers Poker Run May 15th & 16th... http://board.marlincrawler.com/index.php?topic=70852.0
I AM :screwy:!!!
Quote from: TURBO on May 17, 2010, 10:40:41 PM
Let's see some :snapshot: of that :_order:
TURBO
I AM :screwy:!!!
Quote from: TURBO on June 11, 2010, 05:12:50 AM
dude, click the link on my signature!
tssssk that requires an extra mouse click
