Author Topic: Electrical short?  (Read 3285 times)
alinfante
  • Member since Jan '04
Electrical short?
« on: Sep 02, 2004, 12:55:08 PM »
well,
my truck just died on the way home, all the lights dimming and what not. so i replaced the alternator with a new one, and same thing, no charge. so i jumped it thinking it needed to charge a little. came back later and same thing. lights going dim and then nothing. the battery is new, new alternator. i am lost for ideas.
so any ideas?
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: Electrical short?
« Reply #1 on: Sep 02, 2004, 01:05:31 PM »
My head is cloudy as I just woke up, but there is a charge relay and a charge fuse you should check.  When an alternator is on its way out it spikes the voltage and takes other items along with it.
alinfante [OP]
« Reply #2 on: Sep 02, 2004, 04:06:52 PM »
i'll follow the wiring and look for fuses.
thanks,
aaron
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #3 on: Sep 02, 2004, 04:19:14 PM »
You could just check all the fuses in your truck.
alinfante [OP]
« Reply #4 on: Sep 02, 2004, 05:13:36 PM »
did that like three times
Mike D
  • Turtle Points: 122
  • Male Posts: 1,902
  • Member since Jun '04
  • MMMMMMMMMM........
« Reply #5 on: Sep 02, 2004, 05:22:47 PM »
I would check the relays
alinfante [OP]
« Reply #6 on: Sep 02, 2004, 06:21:44 PM »
where are they all?
i got the two by the fuse box, inside the cab. one was an efi, the other was a rear light.
late,
aaron
Mike D
  • Male Posts: 1,902
« Reply #7 on: Sep 02, 2004, 06:28:36 PM »
I'm looking in my manual for ya right know
Mike D
  • Male Posts: 1,902
« Reply #8 on: Sep 02, 2004, 06:29:09 PM »
all i need is what year model ect..
alinfante [OP]
« Reply #9 on: Sep 02, 2004, 08:29:29 PM »
87 4runner 2,4 liter
Mike D
  • Male Posts: 1,902
« Reply #10 on: Sep 02, 2004, 09:35:21 PM »
same as mine
Mike D
  • Male Posts: 1,902
« Reply #11 on: Sep 02, 2004, 10:11:45 PM »
sorry it took so long but i just put in a timing belt. ok there is a headlamp control relay right next to the efi fuse should be silverish. so then next you can trace the red and yellow wire back from the rh headlight and the red and green wire from the left headlight and both of those wire should lead to the combination light and dimmer switch. then there is a red and black wire from the rh head light that changes to a red and green wire after a 10A fuse which leads to the hi beam indicator light then splices over to the head lamp relay and the left headlight has a red and white wire that goes into a red and green wire also after a 10A fuse and also leads into the head lamp relay in the engine compartment right next to the efi fuse.
                                        Hope this helped some how :thumbs:
alinfante [OP]
« Reply #12 on: Sep 02, 2004, 10:22:23 PM »
i'll get on it first thing in the morning. i sure hope this works.
thanks,
aaron 8)
Last post Feb 19, 2006, 03:05:02 PM
by skunkyoda
Last post Feb 05, 2006, 08:30:10 PM
by kneedownnate
Last post Mar 14, 2006, 09:52:09 AM
by CTENG in KS
Last post Jan 05, 2010, 10:02:22 PM
by 4x4yota
Last post Oct 20, 2016, 02:57:18 PM
by 8+1
