weber 34/34
Started by 1983bamayota, November 29, 2008, 01:55:36 AM
1983bamayota
i have a weber 34/34, and everytime i go to stop it goes dead. i have a fuel regulator, and she runs good even on steep inclines. you go to stop and while your slowing down you can watch the tech just fall. i'm running 3.5 pounds of pressure while on the road, and 2.0 pounds of pressure offroad. anyone have an idea what this could be?
Hilux92
Check if the idling jets are not blocked.
1983bamayota
what and where are the idling jets?
1983bamayota
does nobody have a 34/34 weber or what ? i still don't know why it's dying when i come to a stop. if anyone knows, any info would be very helpful
will it not idle at all??  :haha: too many Trailgear parts on it :shhh:
there's a mixture screw on the base of the carb, it needs to be turned out 1 1/2 turns or more if its jetted wrong
btw i have family around Birmingham
Wayne Hale ring a bell??
1983bamayota
 i guess yall are talking about the air/fuel mix needs to be moved out about 1 1/2 turns i'll try that that's for the help. i'm about two hours away from birmingham that name doesn't ring a bell. it took me alittle while longer to figure out that cheaper is not always better. it doesn' pay in the end i know that know. thanks
1983bamayota
i found that yesterday after i posted that.   thamks for the info
