FJ-60 Build-Up
Started by freds40, November 04, 2008, 04:49:25 PM
freds40
Well since I've had a few people ask and the Cruiser forum has been pretty dead lately, I figured I'd throw up a condensed build of my 85' FJ-60. That and I'm pretty bored with the whole no job thing still.  :rofl2:
The initial plan was a 2-3" spring over which is pretty easily done but the body work around the rear tires (quarters and rebuilding the doors) made me shy away from it.
Here it is when I got it. I planned to run 39.5 Iroks so I set one next to it.
Got it thrown into the garage to make it a bit easier to work on.
The top end of the motor was off when I got it so it had to be put back together. Weak-Link was assigned that task.  :haha:
Then I got the front end taken out.
"between projects"
freds40
Threw the front end on my bench to make it easier to work on.
Got it stripped
Then started cleaning off the frame.
"between projects"
freds40
Tires and wheels mounted up
The front end needed a cut and turn and also got widened by 5"
knuckle with 2.5" sleeve
"between projects"
Bazzi
now that´s what I am talking about
freds40
Got the caster set and everything reassembled.
Built a diff cover affectionately known as the batwing. Here's the template.
Welded to the front diff.
"between projects"
freds40
Sleeves and custom length 30 spline inners.
Drilled and tapped the PS box.
The truck is getting an SM465 so I had to rework the nose cone. Marlin gave me a hand on that.
Double wide roller bearing for the pilot
"between projects"
freds40
465 ready to go.
Nose cone bolted up.
4.7 Toy Box ready to go.
"between projects"
freds40
Front spring hangers
Shackles
"between projects"
freds40
Shocks mounted up front
My reworked Surplus Center ram
Lines run @ the Box
You can kind of see the ram in there.
"between projects"
freds40
Axle end ram mount.
Got my carb rebuilt by a 2F carb GURU. One of the best mods on this thing.
Trimmed up the rear quarters.
"between projects"
freds40
As is obvious by the last pic, the shackle angle needed a bit of work.
Heres the front hanger.
Better angle.
"between projects"
freds40
Pulled the tranny
Split-case
Fly wheel
"between projects"
boggerunner
wow, that rig is lookin good, sweet front axle
freds40
Marlin resurfaced the flywheel for me.
Got the tranny and cases stabbed
"between projects"
freds40
Cases prior to install
Got the mini case shifter just in front of the stock console. I was happy about that.
Slave mount
"between projects"
freds40
Rear third got welded. Heavy wall driveshaft installed.
A buddy hooked me up with a sweet exhaust system. If you need exhaust work in the area, get ahold of DHONDAGOD. One of the few willing to take the time on a full custom exhaust.
"between projects"
freds40
Beginning of my rear crossmember.
"between projects"
freds40
Installed.
Stretching the wheelwells.
"between projects"
freds40
"between projects"
freds40
And the first outing this past weekend.
No one with me to take action pics but the suspension works great. Needs a bit more trimming.
Heading for Surf N' Turf this weekend.
"between projects"
freds40
"between projects"
crawlerdan
wow man, that really turned out nice...ive always wanted one, even more now :D
looks great man
Tool Pimp
what happened to the 40????
oddball
Thats one of the most badassed 60s Ive seen, good job, I love the low COG too
46&2
 :bowdown:
This is probably my favorite Fj60 build ever!! Very nice work!! I love your rig. Cool idea with the rear fenders, are you going to fill that little gap in?
:beer:
freds40
Quote from: Tool Pimp on November 04, 2008, 06:35:09 PM
The 40 got parted out. I was going to try and keep both but I'd rather have the family with me on Dusy and Rubicon than run the Hammers solo.
"between projects"
freds40
Quote from: fortysixandtwo on November 04, 2008, 06:56:16 PM
:bowdown:
:beer:
Yeah that's the current project. I'm hoping to have it done before this weekend so I don't load up on sand.
:bowdown:
:beer:
"between projects"
ROCKO
 :sick:
thats a bada$$ 60 right there
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
lucky7
Hell ya i think my chonies are wet :beerchug:
GJToyotabug
oh man thats crazy but you shoulda put the rockwells under it lol nahh still looks good
