FJ-60 Build-Up
Started by freds40, November 04, 2008, 04:49:25 PM
freds40
Thanks. That's on the list for this weekend.
"between projects"
freds40
#61
Start of my new rear axle build. Started with a full width 14 bolt SRW.
Had 2 sets of wheel hubs so I traded 1 set for a set of C&C hubs.
I decided to run the C&C hubs as they would give me a WMS-WMS of 63" while the SRW hubs would put me out @ 67". My front axle is 63" so the C&Cs are perfect while retaining the stock 14 bolt axle shafts.
"between projects"
freds40
The 14 bolt hubs are obviously 8 lug from the factory and I wanted to retain 6 lug on my rig.
First step was to plug 2 of the holes. I cut the heads off 2 of the 14 bolt wheel studs and pressed them back in. Welded the head and turned them on a lather to insure the WMS was flat.
"between projects"
freds40
Next problem was the hub OD. It was way too big for my 6 lug Allieds to fit over so I had to turn down the hubs.
Then I could transfer the 6 lug pattern to the 8 lug hub.
The OD of the axle flange has to be turned down too for the wheel to clear. I took a bit of extra time and cleaned up the shafts a bit. They are still stock shafts though so replacements are a dime a dozen.
"between projects"
freds40
The rotors I used are 8 lug 3/4 ton GM parts.
To attach them, I drilled and tapped the remaining stud holes for 3/4" bolts. You can also see the milled sections for the Toyota wheel studs to seat flat.
Studs pressed in, a little paint, and it doesn't look half bad.
Bolted up and ready to go.
"between projects"
freds40
Now back to the housing.
FJ60 t-cases have the front and rear outputs on the passenger side. My truck gets driven @ freeway speeds and I didn't want to have to worry about drive shaft vibes with an offset t-case/axle.
I decided to build an offset axle housing.
"between projects"
freds40
My goal was to retain stock axle shafts so replacements would be cheap and readily available.
I found that by making the passenger axle tube loose 6" and the driver side to pick up 6" the shafts would swap side to side and give me my offset.
I marked both sides....
and cut away.
Both axle tubes cut. One 6" longer than the other.
"between projects"
freds40
Now to reattach the tubes on the opposite sides.
I machined some sleeves that would fit inside the axle tubes to help align and to give me some backing to weld to.
Drilled a few holes for use as plug welds.
With the tube slid into the axle housing, I used some 3x3 3/8 wall angle iron to act as a jig. With it clamped down, I filled some plug welds.
"between projects"
freds40
Since the housing was out, I decided to shave a bit off the bottom. Didn't want to take a ton and have to plate the bottom so I just too 3/4 of an inch off.
Beginnings of welding up the spiders. I needed some additional traction and this will do until I can afford an ARB for the back end.
I had a couple of pairs of Ruff Stuff SRW disc brackets and I found that by mounting them inside the outer flange, they would be close to where I need them. I have no problems mounting them here as they should never have to come off.
"between projects"
freds40
Got it tossed under there.
Drive line location.
"between projects"
freds40
When I got the 14 bolt, it came with a Ballistic Fab diff cover. It comes in pieces and you weld it together. It's got a 3/8" ring as well as 3/8" plate. Stout piece that will hold up great.
"between projects"
freds40
Got it together and drove it a few days around town and on the freeway.
I was set to run the Dusy Ershim trail for the 4th of July. About 10 minutes from my house on the way there, I felt a small jolt in the back end followed by a slight drag. Pulled over on the side of the freeway to check it and saw nothing. Limped up to the next freeway off ramp and got off. Took a closer look and found nothing. Thought it might have been a wheel bearing based on how it rode after. Passenger wheel hub was warm but not out of the ordinary. Driver was too hot to hold onto. BINGO!!!
After about 3/4 of a turn backing off the spindle nut, roller bearings started to fall out.  :hammerhead:
Pulled the hub and found this.
I made the cut in an attempt to free the inner race, then decided to take a pic. The sealing surface (in front of the seal) was also messed up from the rollers thrashing around on it.
"between projects"
freds40
Sooooooooo long story short, the new axle I built to combat the larger tires and crawl ratio is torn back apart after a wheel bearing killed the spindle and 1 wheel hub. The passenger side hub is still in great shape. Hopefully have it back up and rolling next week as I've got some wheeling to do.  :gap:
"between projects"
Joey88RUNR
pretty impressive! you gots mad skills :clap2: :gap:
freds40
Thanks Joe. Glad to finally be getting back on the trail next weekend.  :driving:
"between projects"
NoPower
Well l just wanted to tell you that your 60 is badazz. I loved my old 60 but I did'nt have the time or money to put into. Looks like you have built a great vehicle that should be alot of fun for years to come :thumbs:
pumkin toy
looks great!  thats pretty sweet you can still run stock shafts in your rear axle :yesnod:
97 4runner Limited
Yota87Truck
NICE!! I relaly like how you modded the rear fenders.  Nice Low COG rig!
buss-stop
Quote from: Yota87Truck on January 28, 2010, 09:16:03 AM
new to this amazing b-board..  your  build up looks rite on... im going to completely mimic it in a lot of ways...  just, JUST got my 84 fj 60 the other day...  quick q- did you widen the rear axle?
buss-stop
im an idiot how about that...
freds40
Some small updates. I've got to do a few things to get it ready for the season. I'll leave for Cruise Moab 2 days after getting back from Tin Benders so it has to be ready to go in a little over a month.
I've been running some pre-production proto-type lower caps on my 25 mm pin kit from the beginning and I finally decided to add new lower caps.
Also went ahead and did the 6 pin mod @ work one weekend.
"between projects"
freds40
The wife went a bit crazy for Christmas.
Rocky helped me out and set up both of my diffs along with some new traction aids.  :thumbs:
I got one of Jess' flanges to run a Toy shaft on a 14 bolt. I had to turn down about 1/4" from the radius to make it fir through the hole that's in the Ruff Stuff pinion guard.
Heres a quick testimonial for our seals. I pulled the front end apart to install the third and even with the extension sleeves I used on the front end and not using an alignment shaft to install them, there is still no gear oil in axle balls.
"between projects"
freds40
This one I've been wanting to do for a bit. Finally had the time one night after work last week. I keyed the knuckles to the steering arms to combat the added torsional loads the tires and hydro assist put on the knuckle studs. Pretty simple mod and it should add a fair amount of strength.
"between projects"
Joey88RUNR
 :eye:  :eye:    thats a nice wifey!     :greengrin: Looks awesome!
pumkin toy
sweet mod with the keyways!  great idea
97 4runner Limited
Slolyfe
Nice work Brendan, I haven't seen your build thread yet! But im along for the ride now. See yea out there this summer.
You'll never take me alive
rgacord
great pics along the way. i like checkin the ideas and the fab work,,,,,,nice job!!!!!
I don't care that "it's a jeep thing" as long as my mail gets here on time
Bazzi
damn... nice idea with the keys  :idea:
:beer:
crawlerdad
Precision guess work done here.
baxter650
Are there plans for an anti wrap bar in your future?
I have been watching your build for a while now, talented build and i love those wheels, i have been looking at the black ones and may step up.
