84 SLO build....UPDATED W/ PICS!!!
Started by toyotamobing, October 24, 2008, 08:58:11 PM
toyotamobing
3rds were both welded, 1st one was done wrong, second was just old gears that have had 25 years of abuse so no surprise there after welding them. i have hysteer but im not installing it to i get the exact springs im going to run because i dont want to have to move my steering box twice. and im going to link it instead of wasting money on canging my rear springs all the time
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
82juguete
Slolyfe:  With your shocks mounted under the bed, they must be in some triangular formation, angling inward at the upper mount right???  In doing this, the shock only travels so much, and the rest of the shock movement is through the pivoting at the actual shock bushings.  I too mounted my shocks through the bed, as running them straight up provides a 1:1 dampening ratio, which I basically think of as best bang for your buck.  Body roll is greatly reduced with this setup, plus it looks cool and makes em say "Man that guy must be serious, he cut up his bed for his shocks!" haha
Sorry for gettin a little :offtopic:
Carry on, cool build!
joey0712
Who started this shocks threw the bed thing?
91 Toyota High pinions f&r.
Aaronn
toyotamobing
so after collecting some much needed upgrades i finally decided to put them on the truck, well most of them.
hysteer kit, 4.88 3rds w/rear spool, new rear shackle angle, new front hanger, diff armor and upper truss. ive also got a flatbed and exo cage to weld on once i get some of the other vehicals out of my yard...
pics to come...
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
el picas82
was that a cow bell  on the front of ur toy toyotamobing
83 217000 22R :hammer:
toyotamobing
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
toyotamobing
everything on and painted...when i drove it it has a bad shimmy/shake after hitting a bump. i ordered a steering stabalizer so hopefully that will help with that
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
toyotamobing
well after some tire swapping im pretty happy with it...minus needing a new master cylinder and having a bent rim causing a small vibration
here are some pics....
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
YOTA yota
joey0712
Where did you get those SWEET 35s son!!!
Slolyfe
You'll never take me alive
toyotamobing
exo is on its way, well i got a pretty good deal on a pair from ernies tire king, and it is just the bracket....also ive got some new front springs with shackles, i installed some new motor mounts which helped out with some drivetrain movement yet now i can feel every vibration!
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
89sastoyo
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
joey0712
Build your duals homo!
89sastoyo
92 2wd DD
first gen cab
toyotamobing
that fawking guy dropped that tcase on the cement twice getting it to my truck....it has no output flange, missing half the bolts, and 1/4 of a shifter
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
joey0712
SOOOOOOOOO I  know how much you payed.... That was still a rippin deal!
89sastoyo
haha as he dropped it I woulda just told him thats 10 bucks off and another lol.
92 2wd DD
first gen cab
toyotamobing
i need to get my tcase gears, new driveshafts, an out put flange, and a top shift shifter or twin sticks
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
axled89
not bad not bad.   your slow build looks fine.    :beer:    what's up with all the different colors/ green bumper.
you should come up with a good color scheme. :biggthumpup:
i love oregon wheelin.
moutaintoys
Lets go break somethin "GO NAVY"
joey0712
toyotamobing
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
<MIKE>
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
moutaintoys
I picked this rig up last night here's my to do list
triple case
lower rear
stock grill
bob bed
arb front
paint paint paint !
get beer stain out of carpit
moutaintoys
painted hood roof & valinc. new fenders &doors to fallow
joey0712
As for the weld/picture under the truss...........Thats just what he's into!  :smokin:
moutaintoys
toyotamobing
hes talking about the thingy and balls that was welded onto the top of the axle truss......and if youve got questions about my truck try asking me not other people....
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
