Built 1985 4runner (feeler)
Started by 854RUN, October 22, 2008, 10:04:28 AM
854RUN
4RUNNER (feeler) what do you guys think??
(In Colorado)
- Newer long block with about 25k to30k,
- Ford Taurus e-fan
- O.B.A
- new smittybilt winch 8000lbs
- rock lights
- 37" mtr's 90% left
- Alcan front springs
- **R151 tranny and Dual transfer cases**
- flat belly
- 13" bob and dovetailed
- built front end with:  longs, lockright lock, 5.29, vented rotors, Tacoma caliper, Marlin brake lines.
- Built rear end with: disc brakes, 5.29, Detroit locker, Marlin brake line, 1linked with tj front coils.
list-o-parts:
DESCRIPTION    PRICE
1985 4RUNNER
RANCHO 5000 (STEERING STABILIZER 9.50")   $49.49
SPRING BUSHINGS (F/R)   $42.00
PRO COMP SHOCKS FOR THE REAR   $73.98
DUAL CASE ADAPTER KIT   $302.76
JOHNNY JOINT (REAR SUSPENSION)   50.25
22RE LONG BLOCK   $1,698.35
BRAKE MASTER CYLINDER (T100 PU)   $33.99
CALIPER, ROTORS, PADS   $127.87
RING GEAR BOLTS   $20.50
TUBING   $124.03
3X2X.250 TUBE (REAR SUSPENSION)   $200.00
HOES, HARDWARE, ECT..   $43.79
LOCKER / 5.29 YUKON GEAR   $700.00
PEDAL CLUSTER   $23.99
IFS BIG BRAKE CALIPERS   $67.05
AIR SUSPENSION PRESSER SWITCH   $19.95
3/4 HEIMS X2 (REAR SUSPENSION)   30
TJ 2" COILS  (REAR SUSPENSION)   $125.00
T/C SHIFT KNOB   $10.00
SPORT COMP 2 5/8" OIL,WATER,VOLTS   $129.85
TAURUS FAN   $68.00
T/C SHIFT KNOB   $9.00
FUEL INJECTORS   $160.99
REAR D-SHAFT   $121.91
DIFF LABOR SET UP   $225.00
MTR 37-12.50X15 AND RIMS   $1,300.00
R151 TRANNY/ T-CASES   $1,000.00
TOP SHIFT T-CASE   $125.00
IFS STEERING BOX   $75.00
HIGH PRO CAM SHAFT   $69.00
DUAL T-CASE CROSS MEMBER   $195.00
KNUCKLE KIT   $75.00
U-BOLT FLIP FRONT   $49.00
U-BOLY FLIP REAR   $49.00
SPEEDO EXTENSION   $24.00
VENTED ROTORS   $78.00
DIFF SOLID SPACER,PINION SEAL, LOW PRO D-PLUG   $43.95
BRAKE LINES   $96.48
HIGH STEER KIT   $519.00
IFS MOUNT PLATE   $66.68
10TH ANNIVRAORY TRANS KONB   $58.20
1 1/2 WHEEL SPACER    $84.00
REAR WHEEL BEARINGS   $242.38
OIL COOLER   $41.00
REAR BRAKE BRACKET   $80.00
YUKON 5.29 (FRONT)   $127.00
5.29 & INSTALL KIT (V6 FOR THE REAR)   $247.69
smittybilt 8000 winch   $300.00
V6 3RD MEMBER   $150.00
1986 REAR HOUSING/ AXLES   $350.00
PROPRTIONING VALVE   $38.94
longs   $250.00
lockright (front end)   $250.00
Have 14k in recipits thinking of  $7000 obo
-JOSH-
854RUN
#2
i dont have any other ones here at work i will post more later
P.S. it has MTR's on it not what you see in the pic
-JOSH-
bigarms23
is the ratio of the duals(2.28&4.7) or dual stock
Shamb
AaronB
854RUN
Sorry for the delay guys
Ratio of the duals is 2.28&2.28
Passes smog with flying colors here in CO for (HC GPM) it put out 0.8961, Limit is 6.000 (CO GPM) it put out 17.9215, limit is 45.0000 (CO@ GPM) it put out 406.3717, limit is N/A?? (NOx GPM) it put out 0.8018, limit is 12.0000.
And ya I would trade I am looking for a 2500 Cummins, Your truck Shamb but 4x4
The t100 is my DD that’s why I am looking to get ride of one of them have to many toy I need a practical DD that can tow
P.S. (Big T) My t100 I will sell for $5000.00 if anyone is interested. Thanks for your replies keep them commin
-JOSH-
COToy91
NO WAY!!! Sad day man, why the feeler?
854RUN
just to feel it lol, i am not going to selling it, but i am thinking sell my t100, i wont another diesel. How is smell up in G-town lol
-JOSH-
COToy91
Quote from: 854RUN on November 04, 2008, 10:10:04 AM
Depends on the day, most the time it is non existant
Doof
854RUN
-JOSH-
87yota83
854RUN
go to the link above i am started a build and am adding old pic. i am adding more pic today.
-JOSH-
