I want to get rid of the auto and install an R150F or R151F 5 speed.Will I need a different cross member? YesAre manual transmission 4 cyl and 6 cyl cross members the same? I believe so, but the mount itself doesn't quite match. Its easy to cut and weld the tab at a different angle though.Is the clutch fork/slave cylinder on the passenger side on V6 applications? [/list]Thanks
I've asked around and everybody agrees that the 4cyl and V6 manual transmission crossmembers are the same. I actually ran across a steal buy on an R151F (4cyl turbo) transmission with transfer case the other day. Now I just need a 3vze bellhousing, a flywheel, pedal assembly and a driveshaft.
I think I've got a flywheel from a 3.0 laying around somewhere. Not sure though, I'll have to check. Shipping would prolly suck for what its worth though.
Started by 95SAS Engine
Started by nut Transmission/Clutch
Started by aussiebobaustin 1996-2004: How-To Guides
Started by aussiebobaustin New Member Check-In!
