exo cage
Started by toyotamobing, October 08, 2008, 09:52:41 AM
toyotamobing
this might be a dumb question but here it goes...will 1.75x.120 wall work for an exo and about how many feet do i need for a simple but nice exo cage?
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
Jordan7118
Is it pipe or tube?
If pipe, make sure you do an EXCELLENT job on triangulation and researching designs. If HREW, DOM, etc., you have a little more flexibility.
Either way, you need to research what you want to figure out how many feet you need.
i would go at least .180 wall  and like Jordan said  do some research,
heres some exo's that i KNOW to work well
a train could fall on that red truck and it wouldnt break,  thats .250 wall tube ( i think :headscratch: )
same as my sliders
Jordan7118
No, .120 is fine as long as you put it together correctly. It's all about how you put that jungle gym together. .250 is way overkill.
TIMS89CRAWLER
Quote from: Jordan7118 on October 08, 2008, 11:01:54 AM
Is it pipe or tube?
the dimensions he just listed are tubing my friend.... obviously as pipe is not listed with a wall dimension
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
.250 is what Michael made my sliders from,  i think that what he used on alot of his cage  :dunno:
TIMS89CRAWLER
Quote from: 79coyotefrg on October 08, 2008, 08:20:15 PM
.250 wall is stupis as hell on a cage thats way too much weight at the top of a rock crawler man......120 is what they build racecars from bro its plenty strong for a crawler
www.choptechfab.com
CHECK THE BUILD
1.75 .120 HREW is good.  that all i use since it is cheap and works well.  it may dent or bend a little with hard impacts but you aren't building a comp buggy.  anything over .120 is overkill.  i can see .250 for sliders but not for a cage.
toy4x4ota
maybe dom for the main hoop but definitely hrew for bracing and everything else
LIFTED TRUCKS ARE GAY
Jordan7118
Quote from: TIMS89CRAWLER on October 08, 2008, 08:20:10 PM
You're correct, but pipe also has a wall thickness. Based on the level of his question, I was trying to cover all the bases.
toyotamobing
its tube...but if its HREW or DOM im not sure yet but i dont care.  ive got an 84 xtra cab pick up truck with marlin F&R bumpers and sliders and i just want to protect mostly the cab and slight fender and bed protection but fenders and beds are easier to replace then a cab...so im thinking of going with 200ft and then useing the extra to build a jungle for my son that converts into a RTI ramp
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
I want to say the average single cab would use about 100 feet.
TIMS89CRAWLER
ya thats prolly bout right! :yupyup:
www.choptechfab.com
CHECK THE BUILD
toyotamobing
oes that include bumpers and sliders?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Sure, but i would get more just to be on the safe side.
kyle@di
 Use DOM. It's not that much more...
DrivenIndustries.Biz
DrivenIndustriesTubeWorx.Com
toyotamobing
at $1 a foot i dont care if its DOM or HREW
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Jordan7118
Quote from: toyotamobing on October 13, 2008, 09:44:55 AM
Whoa... You might wanna check what you're getting. Or is this from a friend? I know DOM is running around $4/foot here and HREW is close behind.
kyle@di
It's your life....You should care...
I used to use HREW when I was working with someone else, and never had any issues other than it denting. But at the same time, it should be done right the first time...
Quote from: Jordan7118 on October 13, 2008, 10:51:27 AM
not that close actually, i get HREW for around $2 a foot.
Jordan7118
Quote from: Hyena on October 13, 2008, 09:00:27 PM
Dang... I suck again...  :hammerhead:
toyotamobing
Quote from: kyle@di on October 13, 2008, 03:02:19 PM
i didnt mean it like that...i know hrew dents but im not worried about dents...im worried about mine and my passengers safty and the overall straightness of my cab.
and yes im getting it from a friend he bought a s**t ton a while back and hes been fabing bumpers and cages and cant seem to make the pile of tube any smaller, and he said since he got such a good deal on it hes going to give me a good deal on it
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
854RUN
Hell i will take a couple hundred feet too.
-JOSH-
pyrosnow911
Quote from: 79coyotefrg on October 08, 2008, 07:52:00 PM
whos is the red one? ive seen pictures of it and i love it i wanna use it fir ideas or mine
al76
^^what about the third gen behind it..Any specs?
F**k Idacurt
