The red rocket *Four link done..... Going turbo
Started by joey0712, October 05, 2008, 10:02:49 PM
skyscraper
You'll be roastin them!!!  Did you find some?
joey0712
Ya one of my buddys in town has some 36s. I also got a set of paddles for the beach.
91 Toyota High pinions f&r.
skyscraper
WHAT?????  Paddles? what size?  I've had my eye on Sammy's 13.00's for awhile now...
joey0712
skyscraper
Wow those are wide... Are you just borrowing them or did you buy them?
joey0712
They are a friends tires... Well my bottle is empty! I almost used the whole thing. I wasted some on testing everything. I havent had any problems so far! I think more people shound get into this stuff! :thumbs:
skyscraper
nice!  When you starting on the 4 link?
joey0712
Ive already started... I just need to cut links and start fittin it all in. Im gonna hit it hard this weekend.
toyotamobing
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
joey0712
maybe.... Will see i gotta get my bottle filled
joey0712
Well i started tearin everything off to fit up the four link cross member. Im sure there is alot of people sad to see my baller shock hoops go. Im fully hanging them on the wall for Aaron and Brett
skyscraper
Hey I dont have much going on this weekend or tomorow so let me know if you need a hand.
toyotamobing
so im guessing those rear springs are ready to go under my truck????
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
joey0712
Yep they sure and the shocks... Ubolts Welded third IFS housing with armor
toyotamobing
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
joey0712
Well i started cutting stuff off today i cut out the old e brake mounts and the horse shoe crossmember. I also cut the torsion bar mounts off and the whole back of the frame. The mounts are also tacked up on my housing.
joey0712
Well i got my rod ends tacked in and bolted up. Tomorrow i will tack the c member in better and see how is flexes. I also picked up an elocker.!
toyotamobing
look at those tig weld tachs!!!!!
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
joey0712
Ya that dude must know what hes doing!
95SAS
looking good, this is what im going to be doing to my truck here shortly.
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
joey0712
Sweet deal! What kind of 4 link are you doing?
skyscraper
Are you gonna incorporate that x member for the lower link mounts into a new t-case x member/skid plate?
95SAS
Quote from: joey0712 on June 10, 2009, 07:51:55 AM
Im going to do the TG 4 link with Air shocks, Planning to cut my frame about how you did.
my build
Aaronn
Quote from: skyscraper on June 10, 2009, 02:57:47 PM
Yes...off the back of the t-case (Frontrange style) and belly pan .......and maybe get ready for front links.
Aaronn
There's obviously alot more work to do on it...This is just mock-up to make sure everything is working as planned
skyscraper
He better have it going before the 4th so he can come play in the sand with us.  And see how that nitrous really works!
John Doe
custom made link brackets, or did you get them some where?
joey0712
Quote from: 95SAS on June 10, 2009, 03:08:23 PM
Hm.... I would do some reaserch before your just buy somthing that "looks" like it will work good. Just my  :twocents:
skyscraper
Quote from: joey0712 on June 10, 2009, 08:26:55 PM
I agree.  I fell for the TG trick myself
