broken detroit
Started by toy4x4ota, September 29, 2008, 03:07:01 PM
toy4x4ota
was at the con this weeked and broke a chromo 27 spline inner and i think that it also took out the detroit.  i have not taken anything apart other then pulled out the broken side, but wanted to know if this is common with detroits.  thanks
dallas
LIFTED TRUCKS ARE GAY
BLACKDOG
If they break when an axle breaks?  No, thats not common.  What makes you think the axle breaking took out the detroit?  You won't know until you pull it apart.
              -Ronald Reagan
88_Pathy
Yeah it is. Can't believe you broke an inner and not the birf though.
lucky7
Might have a similiar problem :rivers:
Rockcrawlintoy
a detroit breaking when u break an axle is pretty common. the shockload from the axle breaking usually does the trick
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
BLACKDOG
Quote from: rockcrawlintoy on September 29, 2008, 04:54:52 PM
:dunno: I've seen lockrites blow up when you look at them, and a few detroits go, but it seems to me like they take the shock fairly well.  Either way, you won't know until you take it apart.
              -Ronald Reagan
I have heard of this with the Detroit's, never had the pleasure but I've only broke one axle ever and it didn't take my locker with it.
Pat
Sharing time between Northern Ca and Western Tn..
toy4x4ota
toy4x4ota
has anyone ever gotten a detroit warrenteed(sp), some one told me that it is possible but i have never heard of that.  hopefully poly performance pulls through with a new shaft
All_Set
This mean you didn't toss in the spare and wheel?
Where are your pictures?
Dave lost two detriots after a birf went pop.
Shouldn't have any issues with Poly.  Lol.
toy4x4ota
no i gave that birf and long side to jeremy so that he could have 3 wheel drive and i just gave him my birf to fix his rig.  i limped out in 2 wheel drive
joey0712
how is your rig on pane? I was talkin to your buddy dave with the white exoed 3rd gen i think. He said your the man to talk to about it. Did u lose much power?
91 Toyota High pinions f&r.
toyotaboy
x2
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
toy4x4ota
Quote from: joey0712 on October 02, 2008, 10:20:54 AM
i just bought the kit from GotPropane.com, you should contact Cary, the owner, he is very helpful with any questions you might have.  As for power loss i did not notice much but maybe a little at highway speeds.  I am no mechanic though so i might not of had it tuned right.  For offroad driving i would highly suggest it
toy4x4ota
when i broke a stock front inner it took out my detriot.  there are these gear type things inside of them and it took all the teeth off both sides.  i tossed another shaft in it but sometimes neither tire would spin.  i'll never run a detriot again.
joey0712
Quote from: toy4x4ota on October 02, 2008, 08:29:39 PM
O sweet deal thanks i have been wantin to run lp for a long time i just dont know if its better then efi.
toy4x4ota
Quote from: Hyena on October 02, 2008, 08:41:14 PM
i hear that, i am over the detroit, time for a welded front
toyotaboy
i still like them, just run 30 splines with em :)
rest in peace Effay
toy4x4ota
ya just needing the cash for the 30 splines, kicking my self now for not getting those right off the bat.  that said the spot that i broke, i feel even the 30 would have snapped, it was bound up bad
nah, you would have broken a hub or ring and pinion.
Pat
the only spot on the
Quote from: toy4x4ota on October 03, 2008, 08:45:41 PM
the only spot that the 30 spline long axle that is the same size anyplace is the splines in the diff,, they are beef..  I have never been able to think why the after market axles are so knecked down in diameter..  I had a set of 27 spline poly axle and they were tiny in diameter..  even smaller than stock..  Granted they were 4340 but still small
toy4x4ota
Quote from: Hyena on October 04, 2008, 09:03:52 AM
didnt think of that
Quote from: Pat on October 04, 2008, 11:04:41 AM
i noticed that too when i bought them, they held up real well for a good amount of time but i guess everything has its breaking point. time to start saving for the 30 splines
All_Set
x2.  You were defiantly going to break something!
Detroit is almost never the item to break 1st.  Unfortunatly, it has a good chance of breaking when something else goes.. (as does any other locker... but there are less expensive paperweights out there.)
Are you hydroed?  If you weld up the front, you'll want to go hydro assist.  (it'll make for easier turning too when you're on your side!!  :D  )
kiyul4130
ya, the detroit is really common to break when a shaft snaps. if your low on cash try and cant afford a new detroit, get a lockrite. i gave my toy front the beat down for 3 1/2 years breaking everything on that axle. the lockrite never had an issue. maybe it was just my luck?
-kiyul-
ECV 7-11
KYOTA FOREVER
toy4x4ota
well looks like poly doesnt make their axles anymore so i am SOL.  time to start saving for the 30 splines.....anyone want to help the cause????
lucky7
Still have'nt torn mine down to find the total damage.Are yougoing to go with a different locker this round?
toy4x4ota
ya going to just put a welded front with a stock inner shaft
