[Project Danger]
Started by NorCalToy, August 21, 2008, 10:24:07 PM
that is absolutely gross... may as well upgrade it to a explorer front diff.
NorCalToy
#91
Quote from: thatHOkid on February 08, 2009, 04:44:09 PM
cant without swapping entire front TTB to explorer. which doesn't bolt on either.
Ranger is D28 and Exploder is D35
B2s and Rangers are interchangeable though.
The pinion was also horribly loose, so i need to clean this thing up and then see if any teeth are chipped or otherwise messed up. If i have to pull a new diff from a junkyard it wont be fun.
:flamer: IFS
no explorer ever had a d30
explorers had a d35 ttb front end
actually you can easily bolt on a d35 from an explorer
NorCalToy
Quote from: jimbo74 on February 08, 2009, 05:03:48 PM
ive been told conflicting info on this one jimbo, ive haerd the Explorer front will bolt on, andi ve aherd it will not. ive done some basic research on TRS. :dunno:
but the 35 diff will NOT fit into 28 housing correct?
:flamer: IFS
get the D35 center part dude and swap it over.. .you may have to get the axle shaft too... whoopty do. it'd be worth it.
go through the D35 and do a minor rebuild and clean it VERY good and re-grease it and fill it with valvoline or napa gear oil (same thing)
I plan to rip the 7.5 diff off my 87 this spring and put it under my dads 95 to rid it of ADD.
Quote from: NorCalToy on February 08, 2009, 05:08:29 PM
it will bolt on, a know a guy that did it, his name is matt (rockranger) on explorerforum
no, a d35 diff will not fit into a d28 housing
NorCalToy
Quote from: thatHOkid on February 08, 2009, 05:17:03 PM
you dont have to swap diffs to get rid of ADD... :screwy:
Quote from: jimbo74 on February 08, 2009, 05:17:13 PM
are the trailing arms/radius arms the same? and all bolt on?
:flamer: IFS
Quote from: NorCalToy on February 08, 2009, 05:23:04 PM
the hubs are different... thats the difference haha... .wow blonde moment.
dont know, dont have a ttb ranger.... do some research
NorCalToy
well, the ring gear has 3 chipped teeth, 2 fairly sever teh 3rd not too bad. ill be getting a new diff for it tomorrow.
:flamer: IFS
NorCalToy
and heres pic verification. :thumbs:
:flamer: IFS
gmack192
I had 2 rangers and a broncoII     That's why I drive TOYOTAS
Quote from: gmack192 on February 10, 2009, 05:47:05 AM
although they don't do bad off road..... their drivetrain BLOWS
gmack192
Quote from: thatHOkid on February 10, 2009, 06:47:44 AM
yeah I know   loved the turning radius of the BroncoII     the 89 Ranger I had I put a 9 inch and dana 44  from a 77 bronco under it 4.56 gears and lockers, then it could keep up with the Toyotas   :lol:
NorCalToy
well 4x4 is fixed. had to put diff in right as it started snowing super hard...  ::)
and about ranger vs toyota, this thing has put a lot of trucks to shame, whether it was truck, driver or other factors, its been a damn good truck to me.
:flamer: IFS
