0 Members and 6 Guests are viewing this topic.
This could be a beautiful truck. I love these suburbans. Rebuild the 350 and some 3/4 or 1 ton axles for it (this is assuming it is a half ton). Throw on an aftermarket carb. Worry about the transmission/t-case if they give you problems. Fix any interior/electrical problems. Maybe re-foam and re-upholster the seats. Throw in some new carpet. Give it a small lift and some 33 all terrains. Throw some paint down and enjoy your cool resto-mod. At leas thats what I would do with it. Have fun with it, I know I would.
Thats the thing though, it IS a beautiful truck! Aside from the fading paint on the roof and the hood, the body is totally straight except for one dent in the passenger door. For now I am going to rebuild or swap the 350 for a running one. Also no need for an aftermarket carb, its fuel injected .The tranny and tcase have always worked great, so I might throw a shift kit in the tranny but thats about it. No interior or electrical problems I am aware of, the interior is still in great shape. maybe replace the rear carpet as it has been a dog/hay/dump hauler for the last 8 years or so. Eventually I would like to upgrade the axles (they are 10 bolts IIRC) and do a little lift but mostly just keep it stock. The thing that kills me is my dad was just going to throw this thing away. If I hadn't came and found him that day broken down, the tow truck driver was just going to take it to the junkyard!! I got there just in time to save it. So in my eyes, he should just give it to me if he was so willing to throw it away like that. I am the kind of person that sees everything for its potential, he on the other hand sees it as a waste of money and time better spent just trashing it.
hopefully he lets you keep it..... my parents are pretty much past the point of letting me keep anything anymore, if its in their name, and has problems, they will get rid of it and buy a new car..... kinda sucks... but its THEIR car.....
I cannot believe i forgot that it had fuel injection. They had TBI since what? 88? Anyways, sorry for the screw up. If the truck is in that nice of shape, I would definately restore it. Fix engine. Fix the dent, paint it. New carpet. If you are going to use this to tow much of anything, I would strongly advise upgrading the axles. Those 10 bolts are pretty weak, especially the rear ones. My friends have blown a few 10 bolts (all my friends drive chevy/GMC, no other toyotas ).The reason I said a small lift was because that rear end is SAGGY!! If you don't want to do a lift, at least throw an AAL or a helper spring setup in there to lift the back up a little. Lifts for those old trucks are cheap enough that I would just throw a lift under it. It is solid front axle right? If so, then lifts are pretty cheap.He should give it to you. You will treat it right. I cannot believe he was just going to junk it! That would be one of the trucks we go to take parts out of at the yard, and end up just buying the whole thing to take home and rebuild. Like I said, it is a really nice truck.
i think its name should be little blue
semi float 14 bolt rear, keep the 10 bolt up front, look for a 6 liter, or simmular 3rd gen GM powerplant, then some 33's, load helper springs in the rear, extra trans cooler, and tow/haul shift kit in the 700r4, then youll be ready to tow in style with enough power to get up them hills. A tbi 350 is a great powerplant, but in a "tuna boat" of a surburban, pulling a trailer will be a struggle on anything other than flat ground.
Just get a running block in that thing, and you'd be good to go! I love the old school suburbans! I wanted one for the family, before the gas prices dictated that I buy a minivan!
It just takes air from around the manifold, if there is a hole into the actual manifold, you probably need to get rid of that manifold with the hole in it, haha. But maybe I am wrong and this TBI stuff is different
Toss it and get one of these!http://www.jegs.com/p/JEGS/751908/10002/-1/11349
Throw some headers on while you are at it
This is true, but they will make it look pretty while just sitting there
Started by roktoy84 New Member Check-In!
Started by daryl New Member Check-In!
Started by Lizard_lips Parts Wanted
Started by Mike D Project Research and Build-Ups
Started by Z0RACK25 Project Research and Build-Ups
