rusty frame
Started by eltigrekid, August 12, 2008, 04:37:22 PM
eltigrekid
hey guys im new on here, but i have an 85 yota that im in the process of putting the marlin crawler 4" spring kit with hysteer and all that good stuff. i live in maine and my frame is junk frome the rear of the cab back. it is at a local shop and they said to find another truck with the same frame and chop the rear half off, so what years are the frames the same? or has anybody built a new rear section just out of tube stock? or plated but they said its to bad to plate. i can post picks if you want.
KDXSR5
You can cut out what is bad and weld in a new section. Or you can replace it all. There was a guy on here at one point in time that built prefabbed partial frames from the cab back. I wish I could find the pics of his setup, but I don't even know where to begin. I guess you could cut it out of another truck, but why do that when you can just make a new partial frame out of new material? If you don't want to build a cab back frame, then I would not plate, if you mean just welding a plate over the rusty parts. I would cut out the rusty parts and weld plate in where the rusty parts were. :twocents:
REG535
maybe u can find an extra frame from another state, or maybe u can u buy a new frame from this guys http://www.budbuilt.com/new/frames.html not sure how much though.
Quote from: ToxicToy on August 12, 2008, 09:28:50 PMmaybe u can u buy a new frame from this guys http://www.budbuilt.com/new/frames.html not sure how much though.
they have been working on said jig for at least 5 years now.......
eltigrekid
ok thanks i think i found a truck but im just wondering if i have a short bed and the donor truck has a long bed will the frames work
*ROKTOY*
Bed mounts may be located different.
Quote from: eltigrekid on August 13, 2008, 07:26:48 AM
no the rear section of the long and short beds are different
on the rear section a 86 or 87 shortbed will also work
*ROKTOY*
Gittinit
I've done both. On my 85 crawler I used 2x3, and 2x4x3/16wall box tube which fit inside the stock frame and built all new to my liking. On my 86 extra cab I also used 2x box tube slipped inside the front and rear section of the frame. I did this to shorten my frame to essentially make a short wheelbase extended cab. The only reason I decided to even reuse the rear half of the stock frame on the 86 was becouse I am putting a bed back on this one and didn't want to fab bed mounts, besides it will look like a stock frame when all is done.
I drilled numerous holes in the frame where the new tube went inside and plug welded for the most weld surface and strength.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
newbe94
i would think that cuttin the rear off is a bad idea cause that will now be a weak point in the frame just my  :twocents:  just try an find a new frame a switch everything over an have a whole better frame an have nothing to worry about
good luck an have a  :beer:
KDXSR5
It wont be the weak point if you know what you are doing when you build a new frame for it
Rytan
I found a bad rust hole by the gas tank on my 86 toy. Here are some pics of how I fixed it.
For the rest of the rust I ordered and applied a rust converter called "1" Step by Interstate Products, Inc.
Good luck with the rust issues. Holler if you need any more info on how I did what I did to fix mine.
Larry
Larry
eltigrekid
thanks for all the help and info, the shop it is getting the frame work done at has found a good rear section off another yota and will be welding it in so i should be good for awhile
unclejpl4x4
wow i thot my frame was rusty :yikes:
sweet 2 see you saving it :thumbsup:
newbe94
Quote from: Rytan on August 18, 2008, 07:33:19 AM
Larry
wow what in the world did the spring hold onto
Rytan
Not much, glad I didn't go offroad with it in that condition. It is strong as an ox now!!
Larry
OOPS
I used to repair big rig trailer frames. Whenever you run plates on the frame, you do not want the ends at 90 degrees to the frame. It will promotes cracking. You want the ends angle cut or V-cut. This applies to any plateing on a frame.
