Make any sense or am I just typing to myself?
so this will make it a lot easier when you go off roadin right? this wont add any traction will it?
ok gotcha. what does the different spline count mean or do?
if you have a chain driven t-case can you still put 4.7:1 gears in it? or do you have to buy a new t-case? i think mine is a chain drive...
more splines is an increase in strength.....
it will not directly correlate to traction of the tires being it is not a locker or a tire itself, but by allowing the slower speeds, there is less likelyhood of stalling out and breaking the traction you do have.... more often than not, its that little momentum you have that will get you over that obstacle
ok so a 21 spline would be fine for my truck?
Your truck will be opened up to the wonderful Marlin Crawler world of after market parts including 4.70:1 low range gear replacements to multiple gear reduction transfer case systems.
When you say multiple gear reduction t-case systems do you mean that there are other gear sets for a transfer case?
The stock gear driven transfer cases are made up of two sections, one provides the gear reduction, or "low range," and the other provides the four wheel drive, or the front driveshaft output. Marlin Crawler, as well as others, sell an adapter that allows us to "stack" multiple gear reduction sections. If you look at the transfer case section of the website you can see pictures of both and you'll notice two essentially identical section at the front with an adapter in between.
i like it better if you explain it with 15 speed mountain bike - the 10 speed one was perfect
Started by wrenchtech Engine
Started by Ney Ney « 1 2 3 4 » General 4WD Discussion
Started by Jason Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
Started by spruce Newbie Questions
