Juds One Ton Single Cab
Started by Jud, July 29, 2008, 10:28:19 PM
0 Members and 6 Guests are viewing this topic.
kamakazecam9
Quote from: Jud on May 15, 2009, 01:56:33 AM
Can you fill it up wil R12? And how much you gonna charge? I can bring it by Friday the 22nd on my way to Fordyce. I don't have to be up there till around 9pm.
I could just refill it with R12 but I found out today that the ac course lab and diesel lab are being moved around so no one will be able to do that stuff until it is finished. Sorry Jud, but if they arevsone by fridaybill let you know
Jud
Only one little dent from Old Sluice. All 3 of my trucks have had the same little dent, it's kind of a accomplishment dent. lol
I walked the wall first try and as usual nobody got pics or video. lol
"bout tree fiddy"
damn bro, you got that damn thing back on the trail in nothin flat.
kudos.
looks good like all your rigs have.
props
:beerchug:
Jud
"bout tree fiddy"
Jud
Quote from: THK90 on May 29, 2009, 01:37:38 AM
kudos.
props
:beerchug:
Thanks dood
"bout tree fiddy"
not a problem.
you got anything planned for it?
or guna rock it like it is for a while?
Jud
Exo cage/tube bed, extend the wheel base, move the steering box further foward for less bump steer, 37's and swap in shaved rear housing.
"bout tree fiddy"
what WB you shootin for?
full exo or partial?
ha im full of questions.
this is going to be your nicest build i believe.
Jud
I loved my 115" on my Xtra Cab and I like my 105" right now so I want around 107-110". I know a few people that love 107".
Full exo but really tight. I don't care if it flexes and dents body panels. I just want to be able to keep at least a Plexi glass windshield and full doors on it.
"bout tree fiddy"
I do agree this SWB is sorta sketchy sometimes... although being short comes in handy in the more technical tight places.
I loved the stability of my ex cab as well. so I get your point there.. 110" would be pretty ideal.
plexiglass eh?
46&2
I like my 107" wb on my 4runner
John Doe
Sweet Vids Jud, I'm looking forward to the rest of the work.
I'm at 107 right now and am considering something more like 110"
95SAS
Very nice work Jud, Also i liked the vids.
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
Jud
I'm waitng on shocks tabs then my new  "Shaved by Duffil" rear housing will go under my truck. I filled in some low spots with welds and flapper wheeled the hell outa the whole axle. All the seams are pretty much smooth.
New axle seals
Before paint
After paint
"bout tree fiddy"
NorCalToy
how much clearnace did you gain by shaving the rear end?
pics look good, truck looks good too. got back on its own feet real quick. :thumbs:
:flamer: IFS
Jud
Quote from: NorCalToy on June 01, 2009, 08:42:56 PM
how much clearance did you gain by shaving the rear end?
Idk how much. Rex told me how much he clearanced it but i don't remember how much he said. lol
Thanks man.
"bout tree fiddy"
Duffil
don't forget to grease that seal before you slide the axle in.
Steve97TJ
What you deciding on the whole bed thing?
98 Taco
97 TJ
Stephen from SC
Jud
I'm gonna build a tube bed when I get tubing
"bout tree fiddy"
Jud
I put the new front main seal in last night and drilled my ps box today. I only got one hole tapped because my tap got tore up. I used cutting fluid and turned back and forth to clean the shavings out. My guess would be the tap was made to tap a pipe and the box is too hard for the tap. Idk
"bout tree fiddy"
Jud
"bout tree fiddy"
yota_krawler
sweet dude, is it a kit or are you putting one together?
Sluice Box Hero
make it happen Jud, just make sure when you are tapping the hole in the side you keep checking it against the fitting you are using so you dont tap it too far.
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
Jud
Quote from: Hunter on June 29, 2009, 09:54:16 PM
TG 2"x6" Ram kit. But I got a 1.25" I.D. tube clamp from Ballistic that I'm going to use for the tie rod mount so I can still dial in the alignment.
Quote from: Sluice Box Hero on June 29, 2009, 10:13:09 PM
make it happen Jud, just make sure when you are tapping the hole in the side you keep checking it against the fitting you are using so you don't tap it too far.
Yea I read that on that FAQ thread. I should have the box back together tomarrow if I can find another 1/4" NPT tap. Maybe even the ram mounted too (depending on if FEDEX comes through)
"bout tree fiddy"
Slolyfe
I got the tap if you need it. I had a hell of a time finding one.
You'll never take me alive
Jud
Quote from: slolyfe on June 30, 2009, 10:01:09 AM
my local ACE hardware say they have one. I'm going to go see if I can make tham liars. lol
"bout tree fiddy"
Jud
"bout tree fiddy"
Jud
Whoo my 1" body lift just showed up.
"bout tree fiddy"
yota_krawler
the starter should be there tomorrow
Slolyfe
Quote from: Jud on June 30, 2009, 04:28:22 PM
Ace wasn't lying. lol
Excellent. My stuff still aint here yet!!!!
