Author Topic: re-jetting weber 32 36 carb  (Read 5553 times)
toeyota
  • Member since Jun '07
« on: Jul 14, 2008, 04:23:34 PM »
i need to rejet my carb. The motor is bored .020 over, 20/22r hybrid with lc cam. Anybody have any ideas on what jets i should start with? Thanks.
BikerTrash
  • Male Posts: 207
  • Member since Aug '06
Re: re-jetting weber 32 36 carb
« Reply #1 on: Jul 14, 2008, 05:44:54 PM »
Well I was going to send you the links to some topics that 79coyotetrg posted a few months ago.
Looks like that was a topic you started too though.
http://board.marlincrawler.com/index.php?topic=45121.msg598366
Got a few tips some people gave there, plus what Glen is running for jets, I think his settup is similar to yours.
http://board.marlincrawler.com/index.php?topic=45121.msg567233#msg567233
I will be rejetting mine this week when I go home but mine is disgustingly stock so I wont be able to help you onec I get mine running correctly.
There is a fine line between clever and stupid, I just wish I knew when I crossed it.
84 4runner
02 Suzuki V-Strom
95 Honda 1100C1
06 Ram 2500 4x4
(please note, listed in order of preference)
toeyota [OP]
« Reply #2 on: Jul 14, 2008, 05:57:39 PM »
yea i realized that i posted the same question awhile back after i posted this post :hammerhead:
Sorry about that. I ordered a kit and ill just trail and error it. Thanks for the reply and sorry for the ignorant double post.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Jul 14, 2008, 07:17:13 PM »
when you pull the top off your carb, right down the jet sizes  and  let me know, pm me
BikerTrash
  • Male Posts: 207
« Reply #4 on: Jul 15, 2008, 12:27:07 PM »
No big deal:D  I sorted my problems out last year I thought, kept fouling plugs, decided to go back and do the job right this time. When i searched your old thread was the first thing to come up, then I folowed one of the links in it and got back to my old thread, it is like a big cirlce now. or a square atleast. Best of luck
84 4runner
02 Suzuki V-Strom
95 Honda 1100C1
06 Ram 2500 4x4
toeyota [OP]
« Reply #5 on: Jul 15, 2008, 03:39:57 PM »
thanks for the help.
Ill pm you in a few days when the jets come in glen.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #6 on: Jul 15, 2008, 03:51:32 PM »
Can we please post it in this thread?  what jets you had, what jets you went with, why, and how well does it work.
Ive always been courious about this.  :yupyup:
I like to Drive!
toeyota [OP]
« Reply #7 on: Jul 15, 2008, 06:31:35 PM »
id be happy to wermz, it may be a week or 2 before the jet kit gets here it was on back order. Ill post when i get the top of the carb off and let yall know what jets are in the carb now. Im going to need help deciding on which jets to install first anyway.
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #8 on: Jul 15, 2008, 10:04:37 PM »
Thanks.  :thumbs:
I like to Drive!
toeyota [OP]
« Reply #9 on: Jul 21, 2008, 05:11:07 PM »
ok just pulled the top of my carb. The stock jets are:  170/140primary
180/150 secondary.
Seems like that should work pretty good with my setup?? It doesnt though Like i said i have the mixture screw turned out about 3.5 4 turns for it to run with best power. I CAN turn the mixture down to about 2.5-3, but it has alot of dead spots and hessitation. So what do yall think i should try out first.
Also do you guys usually swap out the idle jets? Another thing, should i put in the double pumper main jet or leave the single pumper in? Thanks
EDIT: I just got done putting in 180/150 primary....190/155 secondary
Seems to help a little bit. No drastic changes. Ive got the mixture screw turned out alittle over 2 turns not quite 2 1/4. Also i tuned the idle speed screw exactly how the weber directions said and im idleing at about 500 rpm and its alittle rough. Now im not sure if its the cam im running or if i still need to play with the jets. I think the cam i run has 280 duration and 440 lift something like that.
One more thing i just realized. Should i be installing the idle jets that correspond with the other jets in the jet kit along with the new air and main jets i install? For example the corrector jet comes with an idle jet in the same compartment in the jet kit.
« Last Edit: Jul 21, 2008, 07:06:17 PM by toeyota »
Hilux92
  • Male Posts: 89
  • Member since Dec '06
  • Speed Kills...Drive a Hilux and live forever!
« Reply #10 on: Jul 23, 2008, 10:21:12 AM »
I run 145\185 primary and 140\180 secondary.
toeyota [OP]
« Reply #11 on: Jul 25, 2008, 03:24:25 PM »
180/150 secondary.
Anybody have any tips or info on this?
« Reply #12 on: Jul 25, 2008, 04:19:28 PM »
turn the idle speed screw on up to 750 rpm
toeyota [OP]
« Reply #13 on: Jul 25, 2008, 05:10:16 PM »
when  you rejet your carb did you install larger idle jets, or did you leave them alone and install only fuel and air jets?
« Reply #14 on: Jul 26, 2008, 04:54:23 PM »
i only changed the fuel and air jets,  i idled fine so i never messed with the side jets
Last post Nov 08, 2003, 10:34:42 PM
by 4xdrywall
Last post Sep 19, 2004, 08:19:27 AM
by 79coyotefrg
Last post Mar 24, 2005, 03:52:46 AM
by Cheesemaker
Last post Nov 01, 2007, 08:24:21 AM
by TIMS89CRAWLER
Last post Jul 10, 2008, 06:54:16 PM
by BikerTrash
