Hydro assist on the cheap
Started by freds40, July 21, 2004, 11:46:00 PM
swapped89
This is an awesome build. ive heard of hydro assist but never seen it in a build.I like :thumbs:
MaXXis85
Does the same pump mod work on a V6 pump?
axled89
what ram from surplus are you guys running??     can i get a pic or parts number.
i love oregon wheelin.
KYOTA
Quote from: axled89 on October 03, 2009, 12:17:25 AM
did you read the writeup? all the part numbers are listed for everything
<MIKE>
Does anyone know if the pump mod will work for a 4 cyl Tacoma?
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
fj40forlife
Where could you find a 1/4" NPT tap at a store? I seen some online But would ace autozone napa etc have one? is it 1/4x18?
120 Fabrication
swapped89
Quote from: MaXXis85 on August 19, 2009, 09:16:41 AM
X's 2 i got the surplus parts ordered and brackets and a cooler, just need to make my res. bigger and throw it all together. Im hoping the pump mod works on my v6.
freds40
I believe the tacoma pump has a restrictor with 2 smaller holes next to each other. On my FJ60 I swapped that style restrictor for the earlier single hole version and it worked fine. I'm not sure if you can do that with the Tacos or not.
"between projects"
854RUN
Quote from: fj40forlife on December 10, 2009, 11:22:41 PM
Got mine at Napa. But it was a pain to get the guy to believe me that, that size really is a real tape size, i finale had to tell him to just let me see the box of taps they had and ya they had it. good luck
-JOSH-
1997whitefozo
Dang, sounds pretty easy. I am going to have to do this mod!
1997 CTD 487hp 1190tq
1990 bobbed 63's locked 4.7's
-Tyler
possum
Mine came in the mail yesterday. Early X-mas for me :-)
possum
Got the lines all hooked up an got the bleeding started.
i hope it goes fast.
possum
Modafied the reservour today. I used some drive line toob and stretched the stock one 3 inches taller. I also added a tranny cooler.... And got a good start on the brackets. (I didn't have much time to work on it today)
possum
Finished it all up today. Seems to work. I locked it up and did a 10 point turn around in the shop. I steered easy. My only concern is clearance between the ram and the oil pan. 2-3 inches!!!! Does any one have the same clearance and know it isn't a problem? I don't want to lift it any more. Might have to come up with a bump stop.
4XFlyin
Quote from: possum on December 26, 2009, 10:19:41 PM
Post some pictures of your set up. Res and assist mount.
My build up. Getting linked
pumkin toy
good deal man, great you got it done and workin!  how much did it cost? I know the OP said he did it for 100 bucks, but that was back in 2004! i'm sure prices have gone up since then
97 4runner Limited
COToy91
Mine is about that close, I compared it to my tie rod and drag link and their clearance to make sure it would not hit. I have not had it off road yet but i do not think it will
swapped89
What motor do you have?
I know with the 3.0 V6 some people have to swap out there oil pan with a 2wd T100 oil pan and sump to get the clearance they need. Im not sure were i saw the thread might have been on pirate. ill look for it.
swapped89
Found it in the (TOYOTA BIBLE FAQ 2.0-on pirate 4x4) that is one of the most helpful places you can look for any question.
http://www.pirate4x4.com/forum/showthread.php?t=23993
possum
possum
I used 2'' I/D spuare toobing and fish mouthed it to clearance it for swiveling
1/4'' plate for the other end
clearance to oil pan
I flexed it
and found out that the tie rod on the pitman arm hits the leaf spring at full compression.
I built some bump stops after I put away the camera.
possum
Tried it out today. I ran it hard all day at Browns Camp. It steered great. The only thing I wasn't happy about was that the pump whines now. I lost my drain plug on the front diff on a rock. The best I can figure is that I must of left it loose a couple runs ago. Any way I found the plug and put it back in and borrowed a bottle of gear lube.
Pariah
83yotachad
Very good post! This was not getting any action in the other spot so I thought I would post here to.  I ended up with to boxes do to not reading completely. The 1st one I have not been able to get it back together do to them little balls gerr it got me drinking. The 2nd one I got it done and installed yahoo!  I read some where that some one took two stock reservoir's cut the bottom off one and the top off the other cleaned them out and welded them together I have it plumped in I don't think something is wright I have so much pressure that it comes out the bottom of the cap so I took the reservoir out and connected the steering box to the pump and did not have that problem of high pressure but when I shut the engine off it over flows out of the top of the power steering pump even thoe there is hardly next to nothing in the psp before I shut it down. O a little insight to what I have  82/83 toy pickup with a Chevy 283 stock steering pump toy steering box and a 2X8 ram . I might of left something just ask ! Iam open to any ideas .
some day Ill fill out all my info...
in da great upper pen and want to
go wheeling I am just an email and a phone call a way
[email protected]
4XFlyin
Quote from: 83yotachad on January 24, 2010, 12:04:14 AM
This should be some help. This diagram is is for a remote reservoir, but it helps as to where the lines from the box go. Hope it helps.
http://www.howeperformance.com/pdfs/toyota%20hose%20diag.pdf
Jakesteads
ok so i just cracked open my spare box to start working on it and whats with all the little bearing balls or detent balls any info on how to reinstall them???
I like Toyota
4XFlyin
#356
Warning.... Read this other entire thread before attempting this mod. In particular the first page.
http://board.marlincrawler.com/index.php?topic=10579.0
This will save you alot of time and money.
Jakesteads
#357
 :sick: :sick: :sick:  good thing i had a 2nd box lol :D live and you learn ill be doing my other box since u shouldnt take out that shaft!!!!!
I like Toyota
cj2man69
Thanks for the great write up.
looked up the part numbers and it sure saved me a lot of research.
thanks again
854RUN
Quote from: Jakesteads on February 13, 2010, 07:26:04 PM
lol i have been there, use thick grease and cover the balls in it (get your mind out of the gutter) and slowly put them back in, one at a time and let the next ball put the previous. use a lot of grease and it wont be a pain. then slowly screw the shaft into the balls. :biggthumpup:  that sounded so bad lol
-JOSH-
