Author Topic: New Front R&P very noisy on decelleration in gear  (Read 3094 times)
Huhwhye
  • Turtle Points: 24
  • Male Posts: 639
  • Member since Jan '03
  • Huhwhye, esq.
« on: Jun 16, 2008, 04:07:34 PM »
Just has my gears installed and was testing it out and when off the gas the front end makes a lot of noise.  Under power it makes no noise and feels fine.  If I left off the gas and coast with the truck in gear it makes a loud whine.  Any suggestions?
This is on my 4runner that has ADD installed if that matters.  This is a new ring and pinion and has new bearings/parts and ARB installed.
'04 Taco DC 4x4
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
sounds like the pinion depth isnt set right. the last one i had with a whine on decell was caused from the pinion being set too shallow.
sounds like bad setup to me :dunno:
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
That's what I was afraid of. This is my daily driver so getting this taken care of is not going to be easy.
'04 Taco DC 4x4
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
Any chance its the driveshaft.  I seriously doubt it but my installer says that is the problem.  He says if I remove the front shaft it won't whine.  But that sounds like BS because it won't whine since there is no load on it RIGHT?
I'm going to try ZUK's suggestion and try an to pattern it throught the plug hole either tommorow or wednesday when I have the time.  But I need to get this done ASAP.  Taking a trip on the 7/4 and need functioning 4wd.
'04 Taco DC 4x4
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
my rear diff. kind of makes a noise like that and i changed my drive line and it went away... :twocents:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
Was that after new gears being setup?  Mine didn't make noise prior to the gear swap?  That's why I'm skeptical it can be the driveshaft.
'04 Taco DC 4x4
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Are the u-joints on the front shaft timed together?
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
I can only assume so.  I bought the vehicle with 77k miles last december, so I don't really know but I assume the shaft has never been apart since it left the factory.
I do know it didin't make any noise before the gear/ARB install.
'04 Taco DC 4x4
somebody had to remove the shaft  to install the gears,  check to make sure the shaft is still in "phase"
ROCKO
  • Male Posts: 743
  • NOR-CAL WHEELIN
yes it was after i put 5.29's in both diffs.
F@$K CANCER
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
Thank you for the diagram.  I verified that mine looks like the picture.
'04 Taco DC 4x4
that leaves  the  gears being poorly setup  :down:
Huhwhye [OP]
  • Turtle Points: 24
  • Male Posts: 639
  • Huhwhye, esq.
I actually removed the driveshaft since I dropped the diff off for the install.  But I was careful not to let the pieces separate.
Hopefully the installer will be a stand up guy and fix it.  I dropped the diff off to be worked on.  Frankly I don't feel like tearing this thing down again.  I should just take them the whole truck.
'04 Taco DC 4x4
Last post Dec 25, 2004, 09:09:26 PM
by Bob Garrett
Last post Aug 30, 2006, 09:03:15 AM
by toynorcal
Last post Sep 10, 2006, 09:52:56 PM
by Duffil
Last post Feb 22, 2008, 04:17:29 PM
by Orowheeler
Last post Oct 28, 2009, 04:32:57 PM
by toyodaaddict
