Author Topic: dual case vs. single case 4.7  (Read 3374 times)
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« on: Jun 09, 2008, 08:41:06 AM »
dual cases w/ stock gearing and just gearing your t-case to 4.7...
whats the big differences... is it basically just the variation of having different crawl ratios w/ duals?  cause you can go high low and low low
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: dual case vs. single case 4.7
« Reply #1 on: Jun 09, 2008, 08:53:46 AM »
Can we please get an FAQ assembled so I can link to it?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jun 09, 2008, 10:05:00 AM »
:smack:
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #3 on: Jun 09, 2008, 10:15:48 AM »
2 boxes with 4.7 in rear.
High
Low
Super low
Stupid low.
(if you have 2 4.7 gears, I call it Super Stupid Low.)
One box w/ 4.7
High
Super Low
(notice no "low")
Two box w/ stock
High
Low
Low
Super low.
(no stupid low)
Basically, putting a 4.7 in the box saves money (up front).  Then you'll find out how much you really miss your "low" range selection   OR discover you really wish you had "stupid low" and put a 2nd box in.
Most toy 4cyl 35+ rigs will find a benefit from "stupid low" range selection.
I've found that most will want Marlins ultimate set up.  (2 boxes with 4.7 in the rear)  I believe the cheapest way to get there (with 23 splines) is just to buy it all @ once.
MiniSimp
  • Male Posts: 5,120
« Reply #4 on: Jun 09, 2008, 10:48:44 AM »
Just wait and do a Dual Ultimate Crawler
Look at your options:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Jun 09, 2008, 01:58:25 PM »
The standard low is useful for towing heavy loads...............  (either 1L, 1,2,3,4,5 or if it's city traffic 1L,2L,3L,4L,5L )
<----- needed to do that when towing the Valiant
The 4.7 would be too low for towing (plus it would be pretty hard to shift out of the 4.7 low without stopping like you can with the stock low (double clutch upshift out of low to high))
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #6 on: Jun 09, 2008, 02:35:42 PM »
2 boxe
High
Low
Super low
Stupid low.
I kinda like super duper low, and super duper duper low myself.
toyotanner [OP]
  • Turtle Points: 66
  • Male Posts: 1,958
  • low n slow
« Reply #7 on: Jun 09, 2008, 05:13:42 PM »
i always search before i post.
i scanned like 20 bulletins and got fed up.
toyotanner [OP]
  • Turtle Points: 66
  • Male Posts: 1,958
  • low n slow
« Reply #8 on: Jun 09, 2008, 05:18:31 PM »
so the only difference is the selection of ranges then.. ok just making sure.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #9 on: Jun 21, 2008, 03:54:25 PM »
Just buy the single case with 4.7 I ran this for years. Then you dont have to modify driveshafts, cut a hole in the floor, extend your speedo cable, buy new tcase cross member. With a stock 2.28 case your 3rd gear is basically high range 1st gear which means your only two LOW gears are 4L 1st and 2nd. A 4.7 box drops you low enough so you have no overlapping gear ratios(between high and low) with no additional modifications to your rig. 4.7s are a great improvment to your rig. Then down the road you just add a stock box to your existing 4.7 and you have all kinds of ratios. Hope this helps
You'll never take me alive
Last post Oct 12, 2005, 03:46:55 PM
by MiniSimp
Last post Mar 02, 2006, 11:08:54 PM
by toysfreak
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Aug 19, 2013, 06:06:48 PM
by beefyjw
Last post Oct 04, 2019, 04:51:36 PM
by un4seen4
