my 84xtra cab build soon to be on full widths
Started by yotakid707, June 02, 2008, 02:25:34 PM
yotakid707
ok guys im lookin to do a full width swap on my toyota i know sky has the kit for the front axle i need and some other stuff im sick of people tellin me that it cant be done i know it can ive seen it and i need some advice and help with this project the rear axle wont be a problem for me i just need help with my front
ToYocRawleR
What year truck you doin it on?
Check out my build link below i did fullwidth in front with a custom spring hanger n :pokinit:...check it out.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
yotakid707
im doin it on a 84 xrta cab ill check out your build
ToYocRawleR
Dude get the skys fullwidth kit, its super easy and they have awesome products!
Rigs:
yotakid707
where did you find the narrow track waggy axle and what did you use for your front hangers
ToYocRawleR
A guy locally was selling it, it was missing an axle, hubs and driver knuckle, but i got a killer deal on it.  Its kind of a rare axle.  All my hangers i fabbed up myself.
Rigs:
ToYocRawleR
do you have any pics of your truck?
Rigs:
yotakid707
i got some around here somewhere ill post them up in a few that axle on yours looks perfect it dosent stick out too far and your using the stock yota out back but i got a 12 bolt just needs to be rebuilt and my brother is goin to pick up a 10 bolt for my yota in like 2 weeks ima use the sky kit for my front i just dont know how far its goin to stick out on both sides
ToYocRawleR
Quote from: yotakid707 on June 02, 2008, 09:25:13 PM
Thats perfect bro, throw some 5.38s in em weld em up and your set!
Rigs:
ToYocRawleR
Im runin 1.5" wheel spacers in back.
Rigs:
yotakid707
these pics are old i now have a 3.5 lift and 3in body on it but this is what i got
ToYocRawleR
yea it would definetly look sick on fullwidths!
Rigs:
yotakid707
thats what im aimin for and not breaking anything anymore haha but ima use your build up as a reference if thats kool with you.... :thumbs:
yotakid707
only thing thats goin to kill me is ima be driving on the street most of the time till i get my new truck so mudd flaps is goin to be a must for a while haha
ToYocRawleR
Rigs:
yotakid707
im from fairfield in northern california where are you from
NorCalToy
707!!! i recognie that... :yupyup:
530.
:flamer: IFS
Birfailed
I'm going fullwidths as well.  Im doing a 14 in the rear and a 60 in the front.  Going with sky's kit too when I'm ready for the front.  Right now I'm concentrating on the rear.  Did you say your going to run a 12 bolt rear and a 10 bolt front?  I wouldn't plan on much hard wheeling with that 10 bolt.  I'd actually rather run a stock toy axle before a 10 bolt.  Can you try to find a 44 front?  That would be much stronger than a 10 bolt and the 44 is comparable to the toy axle. :thumbs:
The rear 14 bolt with disc conversion.  I just ground off all the factory brackets and spring pads.
My toy rear shafts.  Blew both rear shafts and both 3rd members and one hub on upper Helldorado about a month ago.
Go 1-Ton from the start
ToYocRawleR
I thought i read somewhere that 10 bolts were stronger than the 44s?
Rigs:
Birfailed
Not even close.  10 bolts are junk in my opinion.  Check out my full width build.
ToYocRawleR
They might be junk but the inner axles are stronger than those in a 44 even though they are 28 spline.
Rigs:
yotakid707
rite now ima be taking anything thats getting handed to me i just got a free 12 bolt and now im looking for a front
yotakid707
yotakid707
goin to be puttin the project on hold for a month or so because im moving and rite now havent scored a place with a garage to work in and im not goin to have a computer for a few weeks probley this fawkin sux
kiyul4130
get a 14bolt for the rear.  you can find them for like 50-100 bucks. its for the most part indestructible. $100 is NOTHING to not worry about every breaking on the trail as far as the rear end goes.... do it and be done with it. as far as the front goes, i guess you can only get what you can get if your broke.
-kiyul-
ECV 7-11
KYOTA FOREVER
ToYocRawleR
yea those 14 bolts are fawking indestructable.  I set my gears up hella fast one day so i could go wheelin and didnt have the right back lash.  Long story short the gears were waaaay to tight and caused my diff to start smoking.  I pulled over pop off the cover adjusted the ring gear put in some used hydraulic fluid i found next to some logging equipment and away we went.  Never changed the fluid out in it either.  Ran for days...hahahaha.
Rigs:
boggerunner
yep that 12 bolt still uses C-clips, i wouldnt want to be stuck on the trail with one of those. get a 14 bolt, or dana 70.
kiyul4130
ive read of people running them all day long with no oil in them, filling the diff up with beer, and all sorts of other crazy things to keep it lubed, and they are ok. you can never go wrong with a 14 bolt. its a rockwell as far as im concerned.
-kiyul-
ECV 7-11
KYOTA FOREVER
yotakid707
14 bolt it is then now im goin to have to check the pick n pull for the the front  :beer:
bigarms23
the 12 bolt in the back of my 4runner works fine i did spend the 150 dollars on a moser c-clip eliminater kit no problems yet
