So what's the differences between the 79-85 SA
Started by Tallchevy, May 09, 2008, 08:34:49 AM
Tallchevy
If I remember correctly I read somewhere on this forum about 79-81 solid axles are not the desirable for an SAS. Is that because the bottom axle support or is there other differences. I have tried searching but I can't locate the thread.
87 4Runner redo
EarlKann
Quote from: Tallchevy350 on May 09, 2008, 08:34:49 AM
Yes, (as far as I know) the lower truss is the only difference between the three styles.  79-81 = no truss, 82-83 = mid truss, 84-85 = full truss.  IMHO, the weak part is where the knuckle ball attaches to the tube.  Get yourself some knuckle gussets and run whatever axle you can get your hands on.
knuckle balls are the same 79-85  if it was me  i'd grab a 79-80  and  run the truss on top  so i would have that extra clearance,  i have a 82 axle now though
jonathan82toy
79-80 toyota mini axles -> Rotor bolts onto hub with 6 bolts and the wheel studs are pressed into the hub only. For Land Cruiser vented brake swap you must use 79-80 LC rotors.
81-85 toyota mini axles -> Rotor bolts onto the hub with 2 bolts and the wheel studs are prasses through the hub and is pressed into the rotor.
From the FAQ's
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
Volcom
Quote from: EarlKann on May 09, 2008, 09:00:23 AM
X2  Just make sure whatever axle you run has the stock Aisin locking hubs.  The aftermarket Warn hubs suck.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
fordh8r
I thought only the '79 came with no truss... :dunno:
steveco.
Let's put a smile on that face!
Gittinit
The asco hubs work just as well as the asisin. Both are the same desighn, different manufacturers. The early axles had the asco, and later models had the asisin.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Volcom
Quote from: Gittinit on May 12, 2008, 09:08:20 PM
Thanks for the info, I didn't know about the earlier hubs.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
fordh8r
KDXSR5
I was not aware of this. I will keep this in mind! :thumbs:
cam011
The ASCO hubs are Aisin's.
ASCO = Aisin Seiki COrporation
Gittinit
Quote from: cam011 on May 13, 2008, 05:14:57 PM
Cool I had no idea, I just knew what i had experianced. I assumed different manufacturers becouse of the different names on the dials.  :qtip:
my favorite places:
steveco.
#14
this thread needs some pictures, if i remember correctly, it is something like this.....
steveco.
SocalWheeler71
Only the 79 has no truss. I have an 80 that has the mid-truss.
MiniSimp
