Author Topic: Drain & Fill Plugs  (Read 1809 times)
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Drain & Fill Plugs
« on: May 01, 2008, 08:58:33 PM »
I plan on running these on the drain AND fill. Should I run these as both and why? or only in one place or another? I am going to buy them in bulk, and pretty much be getting them for like $2.50 each including washers...
#90341-18021 drain/fill plugs
#12157-10010 is the steel for the diffs
#90430-18008 aluminum crush washers for the aluminum tranny/t-case
« Last Edit: May 02, 2008, 10:28:40 PM by jimbo74 »
Tool Pimp
  • Male Posts: 1,399
  • Member since Jun '06
Re: Drain & Fill Plugs
« Reply #1 on: May 01, 2008, 09:00:56 PM »
Thats all I run........ for both fill and drain
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #2 on: May 01, 2008, 09:08:33 PM »
Where do you buy them in bulk from?
jimbo74 [OP]
  • Male Posts: 8,707
« Reply #3 on: May 01, 2008, 09:22:38 PM »
any online vendor.... ends up being cheaper places like www.1sttoyotaparts.com , www.trdparts4u.com , or kneedownnate's brother aaron ---- you can buy 1 or 2, but some places charge shipping, and that makes 1-2 impractical for a discount
just gotts price it out, sometimes, they will even pricematch against each other, some don't charge sales tax because of the state they are in, etc
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #4 on: May 01, 2008, 09:24:54 PM »
ahh, I see, thanks for the tip! :thumbs:
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #5 on: May 02, 2008, 08:04:19 AM »
I shaved my drain plugs on the diffs but run those same plugs for the fill holes.  They are nice!!  Much better than the thin 24mm drain plugs that strip just by looking at them  :greengrin:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #6 on: May 09, 2008, 07:56:14 PM »
X2, thats what i did.  never had to worry about the drain plugs twisting out.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #7 on: May 11, 2008, 08:47:29 AM »
Replace them all, then you know what tool you need before you crawl under.
jimbo74 [OP]
  • Male Posts: 8,707
« Reply #8 on: May 12, 2008, 01:32:21 AM »
i broke down and got 10 of the plugs... 6 steel washers, 6 aluminum washers ... to my door from aaron, kneedownnate's brother for $28.88  :D     SWEET!!!!
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #9 on: May 12, 2008, 08:06:48 PM »
Those will still come loose when you grind them along a rock, ask me how I know this. Weld those puppies up and forget them, all you need to know is if you need to add fluid just use the 2 bottom studs for the third member to drain it when you need to. Use a drain plug as the fill plug so that the magnet still catches the shavings.
Last post May 02, 2005, 02:53:49 PM
by guywithuglyyota
Last post Feb 07, 2006, 09:54:37 PM
by yotaboy79
Last post Apr 11, 2006, 10:01:44 PM
by BLACKDOG
Last post Nov 24, 2008, 03:23:49 PM
by Plekto
Last post Feb 12, 2010, 08:53:12 AM
by Cheesemaker
