Author Topic: inner axle seals  (Read 4555 times)
yota pu/runner
  • Male Posts: 208
  • Member since Apr '08
inner axle seals
« on: Apr 29, 2008, 07:21:53 PM »
i need to replace the inner axle seals on 80' front axle my question is the main nut that holds everything inside im looking for the size so i can get the right tool instead of having to try to figure it out.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
Re: inner axle seals
« Reply #1 on: Apr 29, 2008, 07:26:41 PM »
One of these? Its 54mm... I bought the one from Marlin (pictured) Don't forget the Marlin HD inner axle seals! I love mine.
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
« Reply #2 on: Apr 29, 2008, 07:27:42 PM »
Exactly.
« Reply #3 on: Apr 29, 2008, 08:53:52 PM »
if you have some large adjustable  plyers  it CAN  be done,  but  heres the page  Marlin sells  the 54mm socket http://www.marlincrawler.com/htm/axles.htm#knuckles
almost at the bottom of the page
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #4 on: Apr 29, 2008, 08:56:04 PM »
It works and looks great! I have had mine for a year now, and it has been ABUSED and it still looks new (besides the oil/grease/dirt on it) and no paint has chipped off (that I can see). I would reccomend this to anyone looking for a 54 mm socket.
yota pu/runner [OP]
  • Male Posts: 208
« Reply #5 on: May 03, 2008, 04:35:38 PM »
sweet deal thanks i got my seals from marlin but they didnt have anymore sockets in stock and werent sure when they were going to get more.  so now im just waiting.
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • RIP Kyle
« Reply #6 on: May 03, 2008, 05:15:05 PM »
why not go to a tool supply or even a auto parts store to get a socket?
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
BCD
  • Turtle Points: -79
  • Male Posts: 70
  • Member since Dec '04
« Reply #7 on: May 03, 2008, 07:51:05 PM »
I got mine from sears it's a 2 1/8 inch socket and it works great they usually have it in stock so no waiting for shipping to simply loosen a nut
yota pu/runner [OP]
  • Male Posts: 208
« Reply #8 on: May 04, 2008, 08:45:22 PM »
ive checked at the auto parts stores and no one around here carries it but haven't tried sears yet will go there definately tommorrow
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #9 on: May 05, 2008, 05:21:45 AM »
aye, just use the camo method for birf removal and you dont have to touch the wheel bearings (i.e. you dont need that 54mm socket)
Pull locking hub cap and remove snap ring.
Unbolt seal/felts on back of knuckle.
Unbolt brake caliper and tie out of the way. (can be skipped if you have long brake lines)
Unbolt steering arm. (leave bottom knuckle cap alone)
Pull entire outer knuckle assembly off of axle.
Swap in your axle seals
Put it back together.
  • Male Posts: 7,110
« Reply #10 on: May 05, 2008, 05:32:46 AM »
On second thought.....it might be a good idea to check everything out while you have it apart....check those trunion and wheel bearings
you will need the hub socket and a pull scale to measure the pre-load on your wheel bearings upon re-assembly
There are some good write ups on how to do this if you need help
yota pu/runner [OP]
  • Male Posts: 208
« Reply #11 on: May 05, 2008, 05:15:50 PM »
sweet thats alot of good info and where can i find the write ups on this
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #12 on: May 05, 2008, 05:19:43 PM »
While the Camo is good for the trail, in a shop setting I would always do the full tear down.
  • Male Posts: 7,110
« Reply #13 on: May 06, 2008, 05:45:03 AM »
Just curious why, OOPs....... I usually do tear down completely just to check everything out but sometimes take the shortcut if I just had it torn apart recently
  • Male Posts: 7,110
« Reply #14 on: May 06, 2008, 05:46:06 AM »
OOPS
  • Male Posts: 2,561
« Reply #15 on: May 06, 2008, 03:39:52 PM »
For me it is easier to tear it all apart. I have arthritis in my hands and wrists and wrestling that whole unit is a bummer. I also think that if you are going in there to change a blown Birfield you can do a much better job of cleaning it out.
yota pu/runner [OP]
  • Male Posts: 208
« Reply #16 on: May 09, 2008, 07:46:28 PM »
thanks for all the help guys it has been tons of help, and thanks for the link dirtoyboy.
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #17 on: May 09, 2008, 07:54:20 PM »
the camo method has never been short for me.  i have had more problems getting the steering arms off/on then anything else.  go with the HD inner axle seals for sure.  they are a life saver.
  • Male Posts: 7,110
« Reply #18 on: May 11, 2008, 09:10:54 AM »
Yea, you're right, OOPS...... it is a PITA to lift the whole assembly up and get it lined up. I have crapal tunnel in both my hands so I feel ya.... :)
Last post Oct 12, 2004, 10:44:49 AM
by Marketing
Last post Oct 12, 2006, 09:06:05 AM
by FIREBALL
Last post Nov 18, 2010, 05:13:47 PM
by NorCalPR
Last post Aug 14, 2011, 01:25:08 PM
by 93REDCRAWLER
Last post Feb 04, 2015, 12:45:10 AM
by No eye deer
