After driving my 20R with unknown mileage for 6 months, I decided to to a compression test.Results:#1 - 110 psi#2 - 105 psi#3 - 105 psi#4 - 96 psiSo, that leads me to believe that my rings are probably worn, or all of my valve seats are worn and leaking.I guess the low compression explains a few things I've experienced, such as hard starting, running hot, bad gas mileage, and still sluggish in 5th gear with 5.29's and 33's doing 65 on the interstate.Time to start weighing the options...
hey mini, you said you had 80 in one cylinder. don't you have a miss? i thought you needed something like at least 80 psi or maybe it was 85 psi to have fire on the cylinder. maybe i'm wrong.
A miss? I'm lucky the damn thing still runs!
Mine is:#1 - 125#2 - 130#3 - 110#4 - 80
I think toyota calls for rebuilding a n/a r series engine at 122-125 psi maybe
Started by DAWGTOY General 4WD Discussion
Started by kneedownnate Chit Chat Camp
Started by blyota91 Parts Wanted
Started by toby Parts For Sale
Started by dgrant71 Tire and Wheel Tech
