I think immediately doing full throttle pulls would put too much pressure on all the new parts which need to be worn in and work together.
Why not phone a machine shop, they know best?
Don't wait. Go drive normally 'till it warms up a bit, then do some full throttle pulls in 2nd gear from 2K RPM- 4K RPM, then coast, and do again five or six times. That's it. The first 20 miles are critical, and if you wait too long, the rings won't seat and you'll need to re-ring and re-hone. Flooring it early on will force the rings against the cylinder walls, and the cross hatch honing will "shape" the rings to seal against the cylinder wall. If you drive gently, this won't happen, and the honing will be worn off without the rings properly seating.
.......... braking the rings in is about combustion pressure. rpm without load is where you get the rings and cylinder's glazing.
Started by MyToyNotHiz General 4WD Discussion
Started by BLUCRUZ Engine
Started by BLUCRUZ « 1 2 » Engine
Started by dune_it86 Toyota Pickup/4Runner Tech 1979-95
Started by 85yotaboy Toyota Pickup/4Runner Tech 1979-95
