Author Topic: 1983 22R smog question* Now with pics*  (Read 2578 times)
oldschool64bus
  • Turtle Points: -14
  • Male Posts: 78
  • Member since Mar '08
« on: Apr 05, 2008, 02:37:33 PM »
ok so I found a truck I like runs and drives good, been fairly well taken care of BUT I found out today when my mechanic was looking the truck over that it wont pass emissions. Idle was ok but the high rpm was way over. The truck has a Weber, header that has the small tube That runs behind the head and a catalytic converter. The EGR is still there but the hose and airpump are gone. The truck also has Air Conditioning if that makes a difference, can you guys tell me what all I need? I really like the truck but cant see spending 3k on something I can drive legally.
« Last Edit: Apr 13, 2008, 08:17:46 PM by oldschool64bus »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 1983 22R smog question
« Reply #1 on: Apr 05, 2008, 05:59:49 PM »
is your mechanic a  smog  rep??  if  not  i wouldnt trust  what he says to be  gospel
oldschool64bus [OP]
  • Male Posts: 78
« Reply #2 on: Apr 05, 2008, 06:30:36 PM »
he put the gas analyzer on it, it was running rich so it wouldn't pass the idle, he got that down where it should be but it was putting out too much at high idle, hes been my dads mechanic for the last 40 years so we have trusted him but like I say I'm just looking to find out all I can before I drop 3k on a truck.
« Reply #3 on: Apr 05, 2008, 06:46:00 PM »
what weber carb is it??   38  or 32/36 ??
either  one can be rejetted  with leaner jets very easy
oldschool64bus [OP]
  • Male Posts: 78
« Reply #4 on: Apr 06, 2008, 08:19:48 AM »
Honestly I'm not sure, I'm waiting to hear back, not sure if the kid even knows since he bought the truck as is. He never looked into smog because Canyon County doesnt have to smog test.
oldschool64bus [OP]
  • Male Posts: 78
« Reply #5 on: Apr 13, 2008, 07:27:11 PM »
ok so now that I have the truck I've had a chance to get under the hood a bit, I originally thought the air pump was removed but now I am thinking it has the air injection setup, but it is still missing parts, any advice? I still plan on re jetting the carb too. Also there is an O2 sensor on the header but I see no place to plug it in.
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
Re: 1983 22R smog question* Now with pics*
« Reply #6 on: Apr 14, 2008, 08:12:35 PM »
Your missing part of the egr tube that conects to the intake, and some vacuum lines, the plug for the 02 sensor should be on the driver side fender.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
oldschool64bus [OP]
  • Male Posts: 78
« Reply #7 on: Apr 16, 2008, 06:28:26 AM »
but am I right in thinking its an air injection setup? I have no idea since I have only messed with the 20R in my 77.
Last post May 29, 2005, 07:53:16 PM
by BLACKDOG
Last post Oct 18, 2008, 08:48:02 PM
by dt
Last post Feb 22, 2010, 10:57:35 PM
by Plekto
Last post May 25, 2011, 07:49:30 PM
by yotarunner85
Last post Dec 13, 2012, 09:01:48 AM
by Travis H
