Cruiser Axles?
Started by Yoat Goat, April 02, 2008, 01:33:18 PM
Yoat Goat
There is a difference in length between the Fj62's and mini's, but unfortunately I dont know what exactly the lengths are...
T urning
O ver after
Y ears
O f
T rail
A buse
Richmondo
Quote from: Yoat Goat on February 10, 2009, 05:57:00 PM
Are the FJ60 axles C-Clip?
Yeah, they're a C-clip drop-out third member. It surprised the hell out of me when my bro' told me that while installing his Aussie
Quote from: fortysixandtwo on August 27, 2008, 10:48:02 PMIt was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
Yoat Goat
That actually pisses me off... Blast!
Thanks Richmondo!
T urning
O ver after
Y ears
O f
T rail
A buse
Bazzi
the fj-60 axles have a dropp in diff... if that´s what you are asking about.
Bazzi
reply... I haven´t tore down my fj60 axles yet, but how can a drop in diff be a c-clip. ??
about the leangth the front fj60 is about the same with as the rear ifs v6 housing... or about 153 cm...
Yoat Goat
Sorry, Im talking about the rear axles. I seen a FSM pic of an exploded land cruiser rear axle(didn't say what style LC) So I thought I'd ask the marlin guys. Im just trying to clarify if the late model FJ60/62 axles are C-Clip.
T urning
O ver after
Y ears
O f
T rail
A buse
fj-rankenstein
they are most definitelly c clip... you need to take the pumpkin cover off, and you will see a rectangle block in between the spider gears... this is the spacer that hold the axles from floating in and also keeps the c clip in place because of that...
there is a shaft that goes through it and is held in place by a long locating bolt...
remove the locating bolt, let the rectangle block in between the spider gears fall out, push both axles in towards the 3rd member and the c clips at the end of the axles will fall off the end of the axles..
i hope this makes sense!!!
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
Bazzi
this makes sence. but to  me you are descriping an dana axle.... all the cruiser axles I have seen are a drop in diff...
can you post pics of that housing.
fj-rankenstein
yes... all cruiser and mini trucks have a removable 3rd member.....   i have never worked on a dana axle although i have worked on many many cruiser and minitruck axles.. :thumbs:
all cruisers have c clips in the rear diff unless its a full floater...   i dont have any pics off hand...  once you pull the rear cover off the diff you will see what i am talking about..
which rear cruiser axle is this? both are cruisers....
I googled it. :D
I think this is the rear you are referring to.
EDIT: 1978 FJ40 Axles
FJ60 and FJ80s have removable third if I remember correctly.
Hammerhead
The axles in the above picture are regular semi floating C-clip rear and full float front just like most every Cruiser in the states.  There are full float rears too and they have the protrusion in the center of the hub similar to a 14b FF or Dana 60...
Yoat goat - If you are contemplating building one of the aforementioned hybrid axles you can forget about the C-clip because you are using the mini outers which are non-clip.  That also means you can run a front or full float ARB which has 4 spiders instead of the 2 spiders found in a C-clip variety.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
bhigdon101
#41
did they ever make a high pinion 9.5?
i want to build a hybird too.
and want to know what year of lc's axles to look for (front and rear)
are they many different gears for these axles?? and lockers?
will the bobby longs fit into these front axles, cause they are wider right?
who sale's ready to run thirds.. all ready put together just drop in and go...
thanks brian higdon...
daddy always said "if your going to be stupid, you better be tough"
Hammerhead
Quote from: bhigdon101 on March 01, 2009, 04:40:03 PM
Nope...
Quotei want to build a hybird too.
I've used '69, '74 and '78 FJ40 centers but they say the 55, 60 and 62 centers work too...
Quoteare they many different gears for these axles?? and lockers?
Yes, I've seen 3.73, 4.10, 4.11, 4.56 and 4.88...  as for lockers you can get ARB (My personal favorite), Lock-right, Aussie-locker, detroit and others...
Quotewill the bobby longs fit into these front axles, cause they are wider right?
The Bobby longs will fit anywhere factory goods fit.  If you build the front axle to use FJ60/62 inners it will be the same width as an FJ60/62 which is wider than the stock toy-mini front axle by about 3 inches...
Quotewho sale's ready to run thirds.. all ready put together just drop in and go...
If Marlin doesn't have 'em try www.cruiseroutfitters.com
'88 X-cab, V6
Yoat Goat
hammerhead- did full float come in the flavor of 9.5" in the rear?
T urning
O ver after
Y ears
O f
T rail
A buse
bhigdon101
Quote from: hammerhead on March 01, 2009, 11:27:01 PM
if the 60/62 is wider than the mini by 3 in the bobby longs want work right??
i have not seen any wider axles from bobby??
trying to sort all this out before i start chopping and welding....
the dude
Bobby makes a set of inner axles to fit the 60/61/62 application.
The outers are the same for all trucks.  Just make sure you specify what axle housing they are going into and you will be GTG.
Hammerhead
Quote from: Yoat Goat on March 04, 2009, 05:10:41 PM
Yep, I've seen 'em on both FJ40s and FJ60s....
I'm bettin' the FJ60 version would be easier to find.
The thirds are the same though so if building a hybrid you can use any of the big cruiser diffs.
'88 X-cab, V6
Yoat Goat
Any year(s) in particular that are the best? That would be sweet...
T urning
O ver after
Y ears
O f
T rail
A buse
fawndog
FZJ80 will be FF and 9.5" (mid 90's)
Hammerhead
Quote from: fawndog on April 18, 2009, 08:16:57 PM
Yep, forgot that one... :gap:
'88 X-cab, V6
Yoat Goat
T urning
O ver after
Y ears
O f
T rail
A buse
Runar
Shortened 80'series rear (using the short axle on both sides) is a perfect axle for the rear of a hilux :)
Only problem is that it needs 16" rims, although it can be modded to use 15".
Also know about a dude that installed a 60 cruiser axle with offset diff under a 4runner without any problems.  Only issue was that the fuel tank had to be modified to make space for the driveshaft.  Drives fine.
Hilux double cab diesel tdi 1995.  44" Fun Countries, custom coil suspension, streched wheelbase, air operated el-lockers front and rear with 5.29 yukons, MC07 crawler with 2.28 + 4.7 ratios, Hella Luminator Xenon, VHF, NMT, DVD, GPS, laptop and a Recaro child seat for the codriver
Bazzi
Runar. what are you running on the rear and what are you working on for the front ....
Steve_925
i have a 80 rear axle 9.5 ring and i am wondering about running a mini drivshaft with it. does somone make flanges for it, or will a mini flange work?
also i have both a open diff and an e-locker for the axle, if i use the elocker i proble wouldnt even wire the motor because i really wouldnt need to unlock it.
so my question is should i weld up the open diff or use the e-locker. no one seems to want to buy it. ill sell the 9.5" e-locker with no motor for $300
UA 342
STEAMFITTERS
Yoat Goat
Quote from: Runar on May 13, 2009, 11:42:29 AM
Any vibs from the 60 rear under the runna?
T urning
O ver after
Y ears
O f
T rail
A buse
Runar
Nob, at least nothing more then the virbration from the tires themself :)
Also have two friends running Dodge 3500 pickups with Unimog 1300 axles (same offset front and rear) and 54" tires with no problem or vibration at all.  They only complain that the tires wear up fastar than a bottle of a beer on a friday night.
But then again I only have their word for it :)
Note that the Runner has the rear axle relocated some 6 - 8 inches backwards, reducing the driveshaft corners.  Also Icelandic tucks tend to have less lift than USA ones, also reducing the corners.
