MOAB Pritchet Canyon
Started by notajeep, March 28, 2008, 08:42:01 PM
notajeep
Today was our last day in Moab.  Some friends of ours finally showed up and wanted to run Pritchet.  Who are we to stop them. :greg:
Things were going great till we got to chewy (I think that is the name of the big potato salad like hill)  There there was a back up of about 5 rigs waiting for a bunch of rinos to winch up it.
From there we moved on to a no name ledge that is right before the slick rock area that is before rocker knocker.
Then the slick rock area and played around a little.
From there it was on to RK.  I had just climbed this last saturday, so I was certain that I knew the line and was stoked to buzz right up it.
But my good luck with the buggys shake down run had run out.  I had the right line, but it was not to be... got the front driver tire wedged pretty good in that hole, gassed it and SNAP!!!! :mad:
There went a 35 spline cromo yukon outer shaft.  So we turned around and came home.
Fearofrunner
iNfErNaL
Bad ass pics!!!.I was certain I'd be in moab again this year but that didn't happen,hopefully I'll catch up with you and your crew next year.Thanx for sharing the pics.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
notajeep
Thanks guys!  I'll post up some pics of the busted 60 shaft here in a few.
notajeep
:ugh:
You can see that it twisted more than 180 deg before it snaped.  It was the "neck down" style and broke near the u joint end.  I replaced it with a non-neck down spicer peice that I got from Mt Logan.:squint:
boggerunner
nice pics, my buddy snapped a rear 60 shaft in 2 spots in the same place, the rocker knocker hates 60's
notajeep
