Name that Vibration
Started by blackdiamond, March 27, 2008, 08:27:55 PM
blackdiamond
I'm 8 days from driving the bdrunner over 1,000 miles to Moab and I'm trying to get the final bugs worked out.  The t-case issues should be corrected, but I'm still looking for the source of a vibration.
Symptioms: drones in pulses from about 35 mph up, it seems to be the worst under load at the lower speeds, it seems to be reduced when not under load, can be felt at times in the steering.
I had a shop do a quick look at everything and reported no problems.  I'm assuming that they checked bearings, u-joints bolt tightness etc...  I confirmed that they did not check the steering arm torque which I know can cause some strange vibrations.  The rear driveshaft has a little play, but nothing significant.
Any ideas?
Saturday evening I'm taking it to a friends house that is a great mechanic for another look so I'm looking for ideas.
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
gotrocks
Check the steering arms.  Mines has been fixed with that sometimes when I have a slight vib.
93tonkatoy
It all depends on where/how you feel/hear the vibration.
If you feel the vibration in the steering wheel, the problem will most likely be in the front end. If you feel it through the seat the most, then do a careful inspection on the rear. If it is more noise than "feel", I would have a very careful look at the drivelines.
any "play" in the drivelines can cause vibrations. output shaft, u-joints, pinion shaft. Also, how much axle wrap are you getting or what are your pinion angles like?  An unbalanced tire will also "pulse" like you describe, and generally starting at that speed. But you will feel that through the steering wheel or the seat(front/ rear).
SAVE TELLICO post 491
MiniSimp
not only will a non balanced tire do it.... but so will a inproperly worn tire.... [worn off camber]
man 35s not balanced and worn weird.... shakes the hell outta ya.
blackdiamond
I'm planning to get the tires balance before the trip, but I simply have not any time to do much more than work since early Feb.  Nothing in the drivetrain has changed since it ran smoothly so it's possible the steering arms are not tight enough or a tire weight came off.
I did an inspection last night and I  noticed that the rear mount on the lower radiator hose wasn't mounted up so I corrected that, but I'm sure that was another issue.
ToYocRawleR
sounds like a u-joint to me.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
KYOTA
unclejpl4x4
turn off the seat vibrator
I say u-joint
blackdiamond
Quote from: blackdiamond on March 28, 2008, 11:38:20 AM
CV style  :dunno:
should still be phased to a extent
i vote  bad ujoint,  with a toy  u joint if  you can feel slack in them it needs replaced
blackdiamond
There seems to be some play in the transfer case rear output shaft/bearing, how much, if any, is normal?  Should there be any play in the cv end of the driveshaft?
http://board.marlincrawler.com/index.php?topic=44075.new#new
fordh8r
Quote from: blackdiamond on March 30, 2008, 08:20:56 AM
You should have pretty much none.   Is the rear seal leaking?  Also make sure that, If you haven't had your driveline done to fit your config of drivetrain, You also have plenty of spline engagement on the slipshaft.  The less engagement you have the sloppier the driveline becomes and can cause issues.  Just ask me how I know... :gap:
blackdiamond
Quote from: fordh8r on March 30, 2008, 08:38:11 AM
The rear seal seems to be fine, but I can see a slight movement in it.  The differential pinion is tight and has no movement.  The rear driveshaft is built for the application, but was run prior to the rear differential being rotated to correct the angles.  The t-case was run with both a bent shaft for a while and two others (single and double cardan) prior to everything getting lined up properly so I'm sure the bearing has had some stress.  The front t-case bearing also seems a bit loose, but it is only run a low speeds and has never been properly aligned even in the black truck so I'm not surprised about that.
blackdiamond
I got the tires balanced today and all four were off a bit.  It appears that a lot of the vibration is gone, but I'm planning to replace the t-case rear main bearing tomorrow or Wednesday to eliminate all known possibilities.  I pulled the drive shaft yesterday and it appears to be tight.  It's getting closer...
Big Thanks to BigMike for contacting me yesterday with some information and also Jesse from High Angle for returning my call this morning and being willing to help in any way that he could.
:biggthumpup: :biggthumpup:
MiniSimp
Quote from: blackdiamond on March 31, 2008, 11:17:49 AM
Quote from: MiniSimp on March 28, 2008, 06:20:39 AM
Tires balanced? :greengrin:
:greengrin:
blackdiamond
Quote from: MiniSimp on March 31, 2008, 11:19:23 AM
:greengrin:
You done good.  There is still another aspect of the vibration that still exists that I think the t-case bearing may solve.  If it doesn't I'll be feeling good that it will make the trip because everything that could fall off has been checked.
Plekto
Yeah mine did that and the guy at the shop pointed out one tire's was separating like a well, like a tire giving birth through its treads.
Moral - vibrations are bad.  Fix now before something breaks.
blackdiamond
T-case output bearing replaced this am.  :gap:
I'm getting better with the wrenches.  Toyota gave me the wrong bearing so I managed to get the correct one from a local bearing place for under $21 instead of the $68 from Toyota.
:screwy:
gotrocks
blackdiamond
Yes, and No.  The bearing was "loose" again in Idaho but doesn't seem to be any worse in Moab.   :dunno:
