DAMN PITMANN ARM!!!! HELP ASAP!!
Started by Jared, July 01, 2004, 11:07:13 PM
Jared
So im installin power steering on my push n pull setup.  i have to take the pitman arm off of my push n pull box and put it on my power steering box.  only problem is, i broke two pitman arm pullers and 1 3 jaw type puller on it.  its moved probably an 1/8th of an inch.  i got the thing soaked in pb and it is just not budging.  Any advice???????
:bowdown:  :bowdown:  :headscratch: :screwy:
Brian83
Common sense just isn't that common anymore
Jared,
If you've got another puller, then set the puller up and load it as much as you can. Then try passing a torch back and forth on the arm and gradually heat it up. Becareful as the metal expands, it will shoot off, so keep the area clear and work from the side.
Just dont point the torch at that can of gasoline in the corner of your garage or else you will get some more 3rd degree burns!! :flamer:
Jared
thank big mike.  oh yah i tried the BFH.  no good this time.  The ford tool didnt work this time.  never trust a ford...
Brandon
crank the puller down and let it sit, spray some penetrating oil on it and then BFH the pitman WITH the puller on it - works every time for me
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
84runner
A little this :flamer: and a hole lot of this  :_order: never hurt any body
The_Blue_Coyote
Auto zone rents / sells pitman arm pullers. They work great on Toyotas
GOT LEAFS ?
www.bluecoyoteracing.com
84 Totota 4x4 class 7S  #797
yotaboy79
locktup
use a torch, Ive done it several times
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
offroadmission
buy a ifs box w/pitman arm already installed and go x-over. that's what i'd do if i had the time. :twocents: :thumbs:
FOR WHOSOEVER SHALL CALL UPON THE NAME OF THE LORD SHALL BE SAVED. ROMANS 10:13
FOR GOD SO LOVED THE WORLD, THAT HE GAVE HIS ONLY BEGOTTEN SON, THAT WHOSOEVER BELIEVETH IN HIM SHOULD NOT PERISH, BUT HAVE EVERLASTING LIFE. JOHN 3:16
lowgeared
My IFS swap box must have been under water.  After a few days of heat, oil, puller and a big hammer, nothing.  I ended up cutting the arm off.  I didn't need it anyway as I had Marlins new arm that was going on.
KYOTA
Cranked the puller down on mine and made 1 pass with the torch and it shot off.
SWAMPER
