Any Clean Engine Thread
Started by jrock, February 24, 2008, 07:37:52 PM
jrock
Show off your clean engine bays.
KDXSR5
Well, it isn't too dirty... not good shots, but here it is...
46&2
My engine wont stay clean so I stopped trying  :down:
86bobbedtoy
gotta watch this one.
Ill dig some up.
jrock
KDXSR5, your thermo wire fix looks just like mine. :thumbs:
boggerunner
not mine, but a really clean one
Cheesemaker
alwayzbroken
Here is my 85. Completely spotless
emsvitil
#8
My engine compartments are usually cleaner than the exterior......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
KDXSR5
Quote from: jkief86 on February 24, 2008, 07:52:50 PM
Yeah, when I got the truck, the wire was completly snapped off. I need to re-wrap it, it is starting to come undone. I tried to create a more gradual curve with it so the wire would not break again.
jrock
can you buy a new plug with a little stub of wire?
EarlKann
Quote from: emsvitil on February 24, 2008, 09:22:12 PM
Saweeet! 64 Valiant
topar
86bobbedtoy
my old 88 supercharged mr2s built 4agze on juice
last is a buddys that I built
Mine ran 10.9-11.2 on nitrous
his ran 12.1-12.7 no nos
KDXSR5
Quote from: jkief86 on February 24, 2008, 10:23:01 PM
I do not know. I went to a junkyard and went thru a few wiring harnesses in trucks until I found a plug with the wire still attached. I also figured out that you can take apart the plug and replace the wire and put the plug back together, but it is very difficult to not break it. I tried it and broke it, so I just put the "new" one on from the junkyard.
Quote from: KDXSR5 on February 25, 2008, 12:09:27 AM
i have taken apart quite a few plugs and never broken them, jsut need to take your time.... which plug are you looking for? i have a spare harness
KDXSR5
Quote from: jimbo74 on February 25, 2008, 12:12:01 AM
Quote from: KDXSR5 on February 24, 2008, 07:43:21 PM
The one coming out of the radiator tube deal where the thermostat goes. I think it was an 85 only thing, I had a hard time finding one. I broke the metal piece the wire attaches to, and NAPA didn't have a new one in stock, so I just said forget it, I have a used one all ready to go on.
is it the square one? if you can get a better pic, i will see if i have it... i might... cheap :)
Cheesemaker
That was an easy fix on mine.  What I did was, I took it out, and pulled the plug apart and got the metal tab out.  Have patience, you will need a small pick to release the plastic tab holding it in.
Here's how to fix!
Slightly drill out the rubber grommet to a larger size, and place on wire
place heat shrink on wire (don't heat yet~make sure its long enough to stick out of grommet)
strip wire
solder wire to metal tab
slide heat shrink down over the soldered connection and shrink
push connector into the plastic holder
slide grommet over heat shrink and into the plastic holder
put back onto t-stat housing
I tried to look for pics of what it looks like after it was done, but I guess I didn't get a pic of it.  The heat shrink helps stiffen the wire as it comes out of the grommet.  But allows it to bend with out a sharp bend to it.
Another thing I did was got a spare harness, because I spliced in a longer lead on the wires that goes from the harness body in the efi to the coil.  Cause mine was fried, from the exhaust manifold, even through the factory heat shield on the wiring.  I routed mine up along the firewall around behind the brake booster to the coil.  In my pic you can see the white plastic loom, so you can see how I routed it.
TRACKER
#20
my old hondas
Pride - is what drive a man to do his very best even when no one is looking ..
Redbeard1
you can buy the new pins for the connector at the stealership and pop the connector apart and solderand heat shrink the wires to the new pins and put them back in the connector. good as new..
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
4xJedi
'86 4Runner, 4"SAS, 5.29's, 30 spline Longs, locked frt/rr, dual cases w/4.7's, Twinstick, LCE header, K&N, Engnbldr cam, Can-Back, Armor by me.
'97 4Runner
'00 Excursion PowerStroke
toolman
Here's mine before I put it in.
'82 yota work in progress
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
jrock
Damn Toolman, looking nice.
bmxicanrivera
REG535
they all look great, am wondering what top radiator hoses you are using on the 22res, mine top raditor hose hits the air cleaner tube it doesnt have that big drop/bend like everyone else  ??? i guess i got the wrong part number from napa on this one.
JohnHalladay
i just brought my rad. hose onto napa and they matched it up and gave me a new one.
