Doubles.
Started by skipnrocks, February 05, 2008, 09:28:50 PM
skipnrocks
Alright  Iknow yotes are not know for much power and my question is about driveline effeciency.  I know you can loose quite a percent of your motors output as you gothrough the d-train.  So for you guys that run duals on your dd do you notice any power/fuel effeciency changes by having the extra case.....
Yes i am aware that they are an offroad comottie (spell)  and offroad they are the bomb.  I am mainly curious about the guys that still drive on the road?
Thanks
WILLYNILLY
ninja turtle
#1
my buddys running a pumped 22re and when he went duals he said it felt like he lost about 20 hp. his words are that it lost its "snap".
edit: i talked to him last night, he said more like 5hp but he cant light'em up like he used too.
Rockcrawlintoy
i couldnt tell much of a difference
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
46&2
I have not noticed any change in gas mileage or power since going duals. The only problem I have is at about 75 MPH i get a slight driveline vibration because of the shorter shaft and angle. that is the only downside I have noticed. Have only had them in about 3 months. I will have to do another gas mileage test to see if it changed anything. Powerwise it feels the same though  :dunno:
skipnrocks
Cool thanks guys!  It would be cool to see a dyno on it!  Starting at the plain motor, then adding stock d-train and then doubles.
WILLYNILLY
94MtnYote
Good idea,  :thumbs:  wish I woulda dyno'd before I put the header on
Marlin 1200LB clutch
skipnrocks
Does marlin have a dyno?
WILLYNILLY
Nope, but there's supposed to be a good shop in fresno with a well set up dyno.
Hammerhead
Didn't notice a difference...
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
lilbuddy
When I did it in my 81 I noticed a good difference and when I did it in my 86 i only noticed a slight difference.
RIP Kyota.... you are the man
GET IT!!!
SLIVER
My tired 4runner had 52 hp before duals( just a guess), Now with duals it has an even 50 hp.
No matter what there are still just 4 tiny squirrels powering my machine.
))--SLIVER-->
))--SLIVER-->
i noticed no difference at all,  if the gear boxes are really cold,  like when i had to go get my brother in Minnesota,  then   yea  it seems  to lose  some  but after  everything was warm again  it ran  just as strong as it always had
88_Pathy
There is a dyno shop right around the corner from Marlin though.
bigarms23
at first i noticed that it wasent my duals robbing power it was in fact a too high set of ring and pinion gears once fix didnt notice i am running the v6 engine though
Quote from: SLIVER on February 06, 2008, 07:21:08 AM
))--SLIVER-->
where did you get these numbers? i honestly dont think you have 50 hp..... my lawnmower has 5hp.....
Duffil
When I went duals it *seemed* to lose a little bit of power, but it wasn't bad.  I still have the same mileage.
skipnrocks
Sounds like not too much of a differance then, maybe depending on the tiredness of the motor.  Thats cool especailly for those that are using it as more than a trail truck.
WILLYNILLY
SLIVER
Quote from: jimbo74 on February 06, 2008, 12:52:47 PM
I made them up from my very own imagination, i'm sure that i'm way off. Either way, like I said the squirrel thing.
))--SLIVER-->
))--SLIVER-->
Doof
i didnt notice anything... been running the duels for a few weeks now. but nothing major...
Duffil
Quote from: skipnrocks on February 06, 2008, 02:59:55 PM
yes on both notes.  I DD mine, but I can't remember which engine was in it when I did duals. :headscratch:
kiyul4130
normally i could answer this question but either half the junk put in my truck is not mine, then it is, and inbetween all that the trucks broken so much i havent been able to tell yet. i would assume you wouldnt be able to tell because the crawl box is in high just like the back case. its basically neutral not doing anything.
-kiyul-
ECV 7-11
KYOTA FOREVER
Duffil
Quote from: kiyul4130 on February 06, 2008, 08:03:48 PM
that was my reasoning as well...it should be no more than parasitic loss.  But I swear you can feel a difference.  Maybe it's all mental.  the thing to do would be to have an unbiased driver (read: honda guy) drive it before and after.
BLACKDOG
Quote from: no-idea on February 05, 2008, 09:35:35 PM
thats a good description :thumbs:  Not that the 3.0 has much "snap" to begin with, but I didn't notice much, just a little loss of the "snap"  Still cruises fine.
              -Ronald Reagan
Fearofrunner
X2 on no noticed power loss and silvers squirrls... they keep on running in there though :)
94MtnYote
How much weight do duals typically add to a truck?
DTB
Quote from: toyoduh! on February 08, 2008, 03:41:33 PM
I know a case weighs about 75 pounds
skipnrocks
isnt the doubler only part of a case or is that only with the 203/205 box?
WILLYNILLY
Birfailed
goin duals might add 25 pounds, maybe.  but just think when your pulled up next to a fullsize diesel, throw both cases in low and 4.10 gears you'll blow him away off the line.  I did this with 5.29's and I redlined too quick to grab third and by then the dudes turbo was spooled up.  But I got the holeshot for the first 30 feet!
Go 1-Ton from the start
DeadlyPeace
I've been running duals w/ a 22R for about 5 years now in my DD and I have never noticed a difference in power loss. Well other then very first time I tried to drive my truck after installing it. But I then I realized I had the dual case in low. :smack:
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
skipnrocks
Quote from: Birfailed on February 08, 2008, 07:48:00 PM
LOL till you hit your top speed of 7mph   LOL
WILLYNILLY
