Help! 2" gouge in new 42" Irok, can i patch and put in tube, to use for a spare?
Started by Thomas P, January 24, 2008, 09:41:58 PM
Thomas P
I have a near new 42" tire, that ran over a t-post in the snow..... I have a new one ordered, but i would like to use this as a spare, is it possible? Can I have it patched? If not, can I try to patch it and run a tube inside of it? If so, where do i find a tube?? I need some expert advice, thanx peeps.  :beerchug:
'14 Camry SE
SCX10 Honcho on roids!
depending on where  and if its  a trail only,  then it "could" be stitched with wire  then a LARGE  thick patch  put on the inside,
then a tube
Thomas P
'14 Camry SE
although not used much anymore, a tire store should be able to get you a tube
or look into farm supply stores
Gittinit
You may check into having a boot put into that tire, then put a tube in there. I have heard of farmers getting sliced tires valconized (sp), where they bascially melt/glue the tire back together.
With either option I would use it as a spare. I wouldn't risk a blowout, it could be your life or others in the right wrong sircumstances.
A friend of mine runs a boot and a tube in his spare becouse of a simmimar occourance.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Rockcrawlintoy
there is a guy on pirate that sells tubes for tires. weldnmn i think is his screen name
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Thomas P
yeah i definately wouldnt run this tire unless it was an emergency, im not one of those yota tech guys, what exactly is a boot?
'14 Camry SE
Gittinit
Quote from: 1985efiyota on January 25, 2008, 10:59:30 AM
Basically its a single ply of tire that fits the contour of the inside of your tire. It dosent go all the way around but it will cover a large hole so the tube dosent get pushed through, or pinched in the gouge, hole, whatever. It will cause an imbalance, but Its just gonna be a spare from that point on anyhow.
my favorite places:
Tice
we once used about 2 feet of bailing wire, 22 plugs and 40 ounces of slime to fix a slash in a side wall of an SX. It lasted for about 6 more runs!!!! :gap: We did turn it around on the rim so the cut was on the inside.
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
Thomas P
'14 Camry SE
Tice
kiyul4130
Quote from: 1985efiyota on January 24, 2008, 10:32:48 PM
thanks glen! anyone ever done this? or know where to get a tube??
im pretty sure they dont sell tubes for that size tire, or a correct tube. we tried to do it on a buggy for the MC round up and they were incorrect and later found out that that there isnt a right size to just go an by in town. there could be if you go the route rockcrawlintoy posted though...
edit: what about patching it on the inside and using gorilla gluing around it. i dont know a ton about patching so.......
-kiyul-
ECV 7-11
KYOTA FOREVER
skyscraper
I work at tire pros, and we would never touch anything that bad, so I'm not sure you would have any luck taking it to a shop.  Too much liability.  But IMO, I would try to seal up the hole as best as possible (stitch it), put a patch on the inside to cover it up and protect the tube,  and find a tube to put in there.  That way the tube wont want to expand the hole open, and it wont be exposed to the outside.  Hate to see a tire like that go to waste...
Rockcrawlintoy
i see your in magalia. I-5 tire in red bluff will prolly fix it. they fixed a buddys 38'' PJ with about an inch and a half gash. couldnt even tell it was cut when they were done
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Thomas P
'14 Camry SE
Rockcrawlintoy
Quote from: 1985efiyota on January 29, 2008, 02:02:58 PM
really? any idea what it cost him??
it was a while ago i wanna say somewhere between 30-50. oh yeah and you dont need a tube
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
red
if you cant get it patched get the tire foam filled, works great. alot of ranchers and oilfield companies in west texas do that because of the mesquite thorns, never have to worry about a flat tire ever again.
read and comment :whip:
USAF EOD tech
DanS
Quote from: red on January 29, 2008, 02:16:36 PM
Hey Red, how does that foam work on airing down?   :rofl2:
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
skyscraper
we tried that once and it was a dissaster...just my 2 cents
fullthrottle
go to a retread shop like one for big-rigs and have them valcaniz it, but befor you cary your tire in tell them that it is for offroad use only and will never see the road ever. good luck :thumbs:
SASed 94 pu- marlin crawler 4'' springs, 5.29s aussie R lockright F 30spline longs , crawler box and 37'' SSR's
red
USAF EOD tech
Thomas P
i think i will try the vulcanizing, anyone know if there is a place in chico??
'14 Camry SE
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Thomas P
'14 Camry SE
topar
I had two 36" tires vulcanized.  The sidewalls were slashed in a parking lot.  I only use them for offroad now and have been running them for about two years no problems.  I had a tractor place fix them for me.  A buddy of mine had a buddy that worked at the place so it was free.
Doof
hit up the truck stop in corning right off i-5
while your there can you ask them if they tune CB antennas?
