Author Topic: New Brake MC/No Pressure/Wont Bleed!!  (Read 10083 times)
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
Re: New Brake MC/No Pressure/Wont Bleed!!
« Reply #60 on: Dec 23, 2007, 10:35:13 PM »
Take your drums off. Now look at the wheels cylinder. Is there fluid leaking out of it? Now do the same on the other side. If either of them are leaky, then the wheel cylinders need replaced. I wouldn't replace just one, because if one is out, then the other is not far behind. I would assume that for the discs, you just look at the calipers and see if there is fluid leaking out. When you loose all built up pressure, does it come back a little bit after pumping the brakes? If it does, then it has the same problem that mine does. I don't know what the problem with mine is, so...good luck! :thumbs:
THK Matt [OP]
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #61 on: Dec 23, 2007, 11:14:33 PM »
thanks todd, ill check those tomorrow.
if so, ill talk to baconator about the rear end on the truck i sold him.
ill let you know if i figure mine out.
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #62 on: Dec 24, 2007, 08:12:46 AM »
i'm not sure how to check a booster exactly.... maybe undo the vaccuum line and see if the pedal is any different??
Mistaken
  • Male Posts: 55
  • i like lights
« Reply #63 on: Dec 24, 2007, 08:42:53 AM »
usually when you pump the brakes with the engine off and hold them down when you start it the pedal should drop slightly, if it doesn't drop then the booster is bad.
1997 gmc sierra short box 4x4
33"mastercraft MT's
cat back duals
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #64 on: Dec 24, 2007, 08:49:15 AM »
wheel cylinders are on drum brakes, not on disc like a caliper
  • Male Posts: 8,707
« Reply #65 on: Dec 24, 2007, 09:12:15 AM »
THK Matt [OP]
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #66 on: Dec 24, 2007, 02:56:20 PM »
oh no my pedal drops completely.
i have to force it all the way to the floor and then it grabs.
and  thanks for the pics jimbo
lal357
  • Turtle Points: -22
  • Member since Nov '03
  • are we there yet are we there yet
« Reply #67 on: Dec 24, 2007, 07:54:30 PM »
129 bucks....not bad...
nope $106.00 shipped to my door put it on tonight man what a difference it is like night and day compared to the stock one
80yota 22r 32/36 weber,header,custom bed,4.88 spooled rear Aussie front ,63" chevies,cage,yada,yada
Last post Jul 04, 2005, 03:06:21 PM
by mudmaster
Last post Jan 29, 2008, 08:08:50 PM
by 79coyotefrg
Last post Sep 05, 2012, 09:15:07 AM
by Cheesemaker
Last post Mar 19, 2013, 11:42:00 PM
by DeXTer5G
Last post Apr 13, 2014, 09:32:24 PM
by Rocksurfer
