clutch wont bleed
Started by booger1, January 28, 2008, 06:31:44 PM
booger1
clutch will have a little pressure then after holding down for second will lose pressure and sink to the floor causing the truck to take off by itself if in gear with clutch down.  acting like has air in lines, but doesn't because i checked.  replaced the clutch, flywheel, slave cylinder, pressure plate, pilot bearing and it still does this.  now it is so bad that I can't even move it around, because I don't want it to get stuck in gear and hit something.  is there anything I am missing?
93 pickup,  sas'd, 36in tsl's, tundra front clip, taco bed, kenwood, apexi intake,  7mgte.
booger1
Tice
What about the M/C? Did you bench bleed it before after the new slave cylinder?
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
booger1
no, I just put the slave cylinder and tried to bleed it like that. I think I am going to get a new mc and see if that works
brainlessfool
maybe the master is by-passing? any fluid on the floor mat?
Toymin8r
Yes.   It sounds like the Clutch M/C.
ninja turtle
i had a tiny crack in the hard line just above the flare closest to slave on the m/c side. does that make any sence? anyways, follow the line and make sure there isnt any cracks or kinks where air can get in.
booger1
I almost crashed the truck driving it into my garage.  barely went into 1st and got stuck, went to throw into neutral and went too far and went into second and tried again and went into 3rd . :yikes: had to kill motor to stop :shocking:
:yikes:
dude  what part of Arkansas  are you in??  im in Arkadelphia  :wave:
yep  clutch master cyl is GONE
booger1
Gittinit
My buddie ran his taco into my garage. Long story, but he trapped himself between the rocker, and the door, becouse he was standing outside the truck turning the ign on. The truck was in gear and he didn't know it. He was so lucky there wasn't more damage. Now looking back it is pretty funny though. Get that thing lined out before somthing bad happens.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
