Was searching for something and came across this old jew. BUMP to a classic thread
I had death wobble bad. Checked all my front end bearings, tightness on shackles, ubolts everything.....took it to a local auto shop, had em align it. it helped a little but still had it. Took it to my buddy at a 4x4 shop and he told me the other shop flopped up my tow, caster and camber were fine but my tow was way off, he properly aligned it and death wobble no more. If you dont align it properly yourself try a 4x4 shop. fixing the tow made a huge difference.
I had crazy DW on my SAS'd 86. It would get so bad I'd either have to slam on the brakes or try and power out of it in 2nd gear. Tried everything I could think of. Finally someone said every case of DW they'd seen was due to loose shackles. Sure as hell mine were loose. I turned the nuts in another 1/4" and my DW is gone. Drive's like factory now.
First thing that comes to my mind is alignment and caster..what is your toe in set at? I measure mine like thisAlso, do you have steering stabilizer? What method did you use to tighten your wheel bearings? are you following FSM torque specs for shackle bolts, steering arms, etc...and finally how close were are your leafs to being parallel? Mine measure at less than 1/16th"
nice, but fixed it lastnight, it was loose shackels, all good so far, but we took it out for a drive to check the dw and was all happy cause it was gone, jumped on the highway to head home and my timing belt broke. hopeing it dident mess up the heads.
These tabs welded on the shackles really help in keeping the shackles from coming loose. They do not let the bolts turn.
thats a good idea
i wonder if that would help to keep the bolt from seizing to the bushing as well since it keeps the bolt moving against it?
I also cured my DW when I put on a hydro assist.
cause the rams one hell of a strong steering stabilizer...expensive fix but it works haha...Good idea with the bolt tabs... never thought of that...
Started by Broke_Okie_Ty « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Halladay General 4WD Discussion
Started by littlebroii Newbie Questions
Started by toyodaaddict Toyota Pickup/4Runner Tech 1979-95
Started by Rocksurfer Toyota Pickup/4Runner Tech 1979-95
