what r the best snow tires
Started by crazymoritz97, December 18, 2007, 08:42:37 PM
crazymoritz97
hey guys or gals
what r the best tires for snow ?? and what tipe of snow
Chris g Moritz
Geno
It all depends on the driver.  Iroks, SX's, MTR's all do great on 2-4 PSI.
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
yotaboy79
i loved my iroks in soft snow when they where new but now that the lugs are rounded off there not doing as good at gripping some of the harder packed stuff but they still do great in the soft stuff, my old cut sx's did realy good on hard packed and ice and almost as good as the iroks in the powder a friend of mine is running cut and studded 35x16x15 boggers and they seem to hook up realy good but they dont float as good in the powder and the lateral traction isnt very good, and the pitbull rockers seem to do pritty good in most snow conditions as well especialy the powder from what ive seen, id stick with an irok or a tsl sx but thats me  :beerchug:
DTB
anything with large tread blocks/voids and siping is good....hope this helps you
red
i've been having really good traction with bfg mud terrains in my blazer
read and comment :whip:
USAF EOD tech
twistedtoy92
#5
the BFG MT's work very well for me!!!! and i have wildcat ext's on the 84 that have worked pretty damn good in the wet and packed snow at about 10 psi......
Fearofrunner
I blew a bead on 35 bfg mudds at 9.5 psi... i dont think they did that well actually.  You either have to have a real skinny tall tire or a really wide tall tire.   To pack or to float that is the argument indeed
Thomas P
id say iroks are my favorite, when they were brand new they dug in alot and got me stuck a couple times but after they started to wear they wheeled better cuz i wouldnt sink. I went down to 3 psi and they bagged out real nice and i was able to go anywhere.......
'14 Camry SE
SCX10 Honcho on roids!
Gittinit
Have ya tried flipping your irocs around backwards? You would be making the outer lugs into more of a grabbing edge for the hard frozen stuff, and the softer snow might get pulled to the center to help you stay on top.
I don't have experiance with snow but in the soft sand my irocs work best in the standard direction, as they will dig , and pull. With them turned around backwards I loose out on the really soft stuff couse all the soft sand gets pulled to the center of the tire. It just might work in snow though as snow tends to stick to itself.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
toyotanner
when i first got my truck a long time ago it had a set of 33x12.5 wildcat ext's on it and all my friends said they do good in the snow.... but never used them :dunno:
but my ssr's did really well when i went snow wheelin this last weekend didnt airdown but i got decent traction on the ice and the fluffy stuff
bigarms23
i am running36inch mickey thompson mtzs and so far they work great in snow aired down or not and really great on the ice
Gewehr43
Haven't got new tires to test out after my lift.  Before the lift I had a cheap set of 30X9.50R15 Dominator A/S.  Don't laugh but I never got stuck or lost control.  I would think that any tire that has more tread voids the better.  My brother had a set of 31X10.50 BFG At's and they did great!
Then again it depends on how deep and what kind of snow as well as a ton of other factors.  As for the packed crap on the roads the above mentioned tires faired well.
twistedtoy92
ive got the 30x9.50 BFG MTs and i love them.... almost worn out tho!! ive had the best luck with tall skinny tires due to the fact that you have more pounds per square inch so they tend to dig and bite better.... but if you are going the floating method the wider the better!!!!
Plekto
My BFG MTs are excellent.  But I am running stock size as well, so they are very much on the thin and tall side of the equation(they dig in very well).
30x9.5 is one size larger than stock, IIRC, so it's about the same.
Of course, this is mostly for snow on roads and places with 4-8 inches of it and something hard underneath.  (digging down works).  Out in a field with 2-3 feet of snow, floating is better.
Angler
BFG MT are very good, Here in alaska guys take them and have them siped an they really do good on the ice, I have swamper tsl on my jeep and they do pretty good but they get really bad flat spots because they are bias ply.
Hammerhead
As mentioned above it really depends on what type of snow driving you plan to do.
If you are talking about icy snowpacked roads it is hard to beat BFG ATs.  I live in Utah mountains and run BFG ATs religiously on the family SUV.  You'd have a hard time finding a better tire for that application.
On the other hand for taking my Toyota out in the deep stuff I'm running 38.5 SXs and they go through the deep like mad.  I'm sure it helps that I'm running a V8 but I can't imagine a lesser tire ripping through the "FOOFOO" powder like these babies do.  They sure flatspot at night but it goes away after driving a bit.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Thomas P
i recommend siping all tires that will come in contact with snow/ice, i siped my iroks and they were like night and day on ice
'14 Camry SE
